packersfan036 Distinguished May 27, 2015 1,691 25 19,820 Feb 20, 2017 #1 I have the arctic liquid freezer 240, and a asus z170-a motherboard. should I set the pump to dc, pwm, or disabled mode in the bios? I was thinking pwm, and it is currently set to disabled. I'm just asking before I start messing around.
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Feb 20, 2017 #4 The pump has a 4 pin connector. dc is for 3 pin. Upvote 0 Downvote
packersfan036 Distinguished May 27, 2015 1,691 25 19,820 Feb 20, 2017 #5 right now its set to disabled, what does that mean? Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Feb 20, 2017 #6 That the pump speed is not controlled, based on temperature. It runs at full speed. Upvote 0 Downvote
packersfan036 Distinguished May 27, 2015 1,691 25 19,820 Feb 20, 2017 #7 oh ok cool. so should I leave it set to disabled? Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Feb 20, 2017 #8 Does everything work? What cpu temperature getting? Upvote 0 Downvote
packersfan036 Distinguished May 27, 2015 1,691 25 19,820 Feb 20, 2017 #9 ya works great 24-26c at idle, and under gaming loads around 45-50c, and under very heavy loads like unigin heaven and aida 64 it starts to creep up. Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Feb 20, 2017 Solution #10 If noise does not bother you, you can leave it as it is. Upvote 0 Downvote Solution
packersfan036 Distinguished May 27, 2015 1,691 25 19,820 Feb 20, 2017 #11 ok thanks Upvote 0 Downvote
