Water RGB Build
hsabbagh
34
Hello,
My build is almost completed but my problem is with the case.
https://pcpartpicker.com/user/hsabbagh/saved/vy3mGX
What I need is:
good airflow
kraken x62 support (custom water cooling is a plus but not required)
2 SSD + 2 HDD (Very important)
Glass (big plus)
PWM Fan support (big plus)
My options are very limited, which are:
S340 Elite
S340
Noctis 450 Matte - Black
H442 red/black
Coolermaster master maker 5
I dont know if these cases will fit all of my parts perfectly.
I have the CPU air cooler now, but getting the kraken x62 later.
Thanks
Get a P400 tempered glass. I have one. The whole viewing side is glass. Case comes with under lights and an rgb strip. The power button led also follows the colors.
Check out mine:
https://pcpartpicker.com/b/MGXPxr
It does more colors than blue.
Fits all your parts. The cooler goes in the front. It's $89 I'm pretty sure in Amazon or Newegg.
Please note that custom loop is different than closed loop AIO water coolers.
Too bad the TG option is not available and would cost me 340$ if I want to ship it 😀
