Water Spilled on my pc
Jun 12, 2018
i spilled not much but still hit my vga card and my motherboard was showing orange light in the top right corner and then shutup
what is the orang light in the top right corner means?
Mobo : B350f
shknawe
Respectable
Oct 22, 2016
1,288
45
2,490
134
Remove the power cord from your computer. Take a look at everything to make sure there is no water anywhere. If there is dab it up with some paper towel don't rub. Take a hand hair dryer and on low heat and blow dry the area where the water hit.
Let it sit open overnight and then repeat the blow drying. Then try a restart after inspecting for any moisture. I don't have to tell you how bad ANY amount of water is for a computer.
shknawe
Respectable
Oct 22, 2016
1,288
45
2,490
134
