B Bi11hi11y Commendable Feb 26, 2016 54 0 1,630 Mar 12, 2016 #1 OK guys, should I go with the Cryorig H7 or the Corsair Hydro H60? I doubt I'll be doing much overclocking. CPU: Intel Core i5 6600k Motherboard: Gigabyte GA-Z170XP-SLU Case: Corsair Carbide SPEC-02 Mid Tower. Thanks!
Solution Dark Lord of Tech Mar 12, 2016 H7 is not really noisy , uses 1 fan an is fairly quiet. An additional , good quality fan at the top exhaust shouldn't be very noisy.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,658 1,801 159,590 Mar 12, 2016 #2 The Cryorig H7 is a much better cooler , it can cool almost as good as a H80i. Upvote 0 Downvote
B Bi11hi11y Commendable Feb 26, 2016 54 0 1,630 Mar 12, 2016 #3 I'm worried about the noise level though. I'll be adding an additional fan on the top of the case. How noisy will it make the rig? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,658 1,801 159,590 Mar 12, 2016 Solution #4 H7 is not really noisy , uses 1 fan an is fairly quiet. An additional , good quality fan at the top exhaust shouldn't be very noisy. Upvote 0 Downvote Solution
B Bi11hi11y Commendable Feb 26, 2016 54 0 1,630 Mar 12, 2016 #5 OK, thanks a lot! Air cooling it is! I was kinda leaning to it before but I'm certain now. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,658 1,801 159,590 Mar 12, 2016 #6 It's a great little cooler , I own 4 Cryorig coolers , H7 , best value on the market. Glad to help , thanks for posting on the forum. Upvote 0 Downvote
