Custom P.C. Built by previous owner,
Seeing CPU Temps: Idling at 51C, Under Load (Gaming) 98-100C (Throttling I assume.)
Mobo: Asus Z170A
Chipset: I7 6700K (4ghz, Default BIOS)
CPU Heatsink: Arctic Liquid Freezer 240 (4 x 4'' fans)
Case: Corsair Carbide High-Ariflow (3 x 5'' case Fans)
GPU: GTX 1060 (6G, factory overclock)
Ram: 2x 8G Corsair Vengeance DDR4 2133
O/S: Windows 7 64-bit
I have been seeing the red over-temp light on the motherboard turning on while in-game, but when I checked my temp in the bios it was in the high 70s.
At this point I started my research, made sure the Water Pump was connected properly (Water pump header on the board), etc and found everything was fine as far as I could tell.
The previous owner had some overclock settings enabled so I reset the BIOS to default settings.
Now I'm wondering if the default settings can cause higher CPU temps? I had a quick look at the list of options it changed, core voltages -> auto etc.. Would the BIOS allow the core voltages to reach temps like this? And should I go through and manually set limits?
I have never overclocked or played with BIOS settings like this before, and I'm excited to learn, but don't want to damage anything or create a mess, so some advice would be appreciated.
P.S. I'm going to the store tomorrow to get some new thermal paste, and I'll re-seat the heat sink.
P.P.S. Open Hardware Monitor is showing ~35% CPU load and 12W Power while at temp of 100C.
Mobo: Asus Z170A
