So I made a water cooled custom PC last year with soft tubing and while I wasn't exactly disappointed, I was not amazed either (check it out here at this link, https://pcpartpicker.com/b/fTkTwP) So as far as it goes, a pretty sweet soft tubing build leading me to believe that I can make an even more amazing hard line tubing build.( i can hope, right?) anyway, I need some help. I am doing a new build with acrylic. Here is my idea.(https://www.dropbox.com/s/let87f7uga1h4wk/81Sjs8ScdZL._SL1500_.jpg?dl=0)
First off, when I was doing this build I used a good amount of fittings. 14 I think. That will be fairly expensive to replace. in my new build, I would like to have it be color neutral. EX black fittings and add RAM cooling so my ram sticks are not blue, but whatever color I use for fluid. I do not want to have to redo this. Could any of you help me find fittings that look good, but will not cost more than 140$ for 20 of them? I am adding at least 4 fittings due to RAM cooling as I now have 8 RAM sticks to cool.
My second issue is tubing size and fill ports. In the picture I made of my new tubing route, I find it hard to find a spot for a fill port. How would I fill it based on this picture? where would I add a T connector or something?(go to dropbox pic)
Any advice for a new user of hardline tubing and acrylic?
What should I change? which colors should I use or water blocks to make this the most color neutral? in my PC build, find everything blue and find a way to make it neutral if that makes sense.
