Watercooling HELP PLEASE
Obliq
I'm looking to get a watercooler for my PC build. I've been told that they are a lot of work for example bleeding them, but I've came across the Corsair Hydro Series H100i and people have been saying that you don't have to bleed it and its just install and its ready to go. Is this correct?
To be perfectly honest, I wouldn't call it watercooling, even though it employs the same principles as bigger loops. The entire cooler is packaged from the factory for you to just install and walk away. Performance will be on-par with high-end air coolers, or so.
