I plan to build at the end this summer with money I'm getting for college (free tuition
) and I have all the parts planned and as for the watercooling part I am going to get
http://www.petrastechshop.com/swapgtzcpuwa1.html for my CPU block
http://www.petrastechshop.com/swmcnowa.html for my Chipset block
http://www.petrastechshop.com/swkofuwaforn.html for my GPU block
http://www.petrastechshop.com/swmcqposerab4.html for my Radiator
http://www.petrastechshop.com/swmcin12pu.html for my Pump
All with 1/2" inner diameter tubing.
Now my question in all of this is how exactly should I set all of this up? Should i go just one straight shot through it all? just rad-pump-chipset-gpu-cpu-rad or shoud I perhaps Y off and go to just the GPU on one side and then to the CPU and then chipset and Y back together and to the radiator? I have never actually done watercooling but I've looked around a lot and built a crap ton of PCs, just never done water cooling. So I'm looking for suggestions before I spend about.... 400$ on a water cooling setup haha. Thanks in advance.
Edit: This will be in an Antec 900 and I will be using the Radbox (http://www.petrastechshop.com/swmcrre2raho.html) to mount it on the back of my case. The pump will be on the inside infront of the power supply, I've got really good cable management so this won't be a problem.
) and I have all the parts planned and as for the watercooling part I am going to get http://www.petrastechshop.com/swapgtzcpuwa1.html for my CPU block
