XSPC double 120mm radiators, XSPC raystorm CPU block, XSPC Razor GPU block, some form of D3 pump, possibly with a reservoir combo.
These are good mid ranged options, certainly not the best or most expensive but suitable for all but the most demanding overclockers.
Which country are you buying in, what case do you have and what is your budget?
