Watercooling Overclocking Help
ethandrelles
Commendable
Jan 20, 2018
33
My case supports a 240mm radiator intake and a 240mm radiator exhaust. Will this be enough to comfortably cool a ryzen based processor and two graphics cards?
2 x 240mm rads is enough for an Ryzen 7 and two 1060`s in SLI + Overclock.
Just dont go for slim rads and to low FPI (Fins Per Inch)
And you better be prepared to hear your fans since you will most like not be able to run a silent system.
right now I have a ryzen 5 1600 and a gtx 1060 ssc but I plan to be upgrading down the line to an SLI configuration and maybe a better processor
This is 'kind of an OK way' to approach loop building and will often get you close enough, but the best course of action is to find the total loop TDP and check what you'll need based off total watts possible.
For example, a 1080Ti or Titan would fall short with this planning if coupled with a high-end CPU, and definitely if either are overclocked.
I wish this forum had an option to link nicks in topics to alert the individual to the topic.
I know JackNaylorPE have done some kind of "radiator", "watts", "calucaltor" somewhere, so he might be able to shed some light on this topic...
Myself I just follow one simple rule when it comes to watercooling and radiators:
Fit as many the case you have can handle. If that still is not enough. Get a bigger case or start modding 😀
Haha, I can relate to this! I've just finished moving my system into a Core X9 case for this very reason.
Shiny; I'll have a look at that :)
