Ok. And do you PREFER to stick with an AIO cooler, or are you intending to make a switch to air regardless of whether you could fit a decent AIO into your budget or not? In other words, if it can be done within that budget, would you RATHER go with an air cooler or a water cooler? Either will work fine, but my primary consideration when it comes to air vs water is that the water cooler WILL fail at some point. And there are multiple failure points.i can push it to $135 if necessary.
i was going to buy a usedFor that budget there are no AIO coolers of sufficient quality or capability that I'd choose over air coolers that you CAN get for within that budget that are more than enough for that CPU.
What region/country are you in?
What is the make/model of your case?I am planning to buy a cooler for my i5-9600k which doesnt come with a cooler. I have a $70 budget, so which is better; a closed CPU watercooling unit or a fan cooler?
i have plenty of room for liquid cooling. I have a COUGAR Panzer MAX. I plan to have the radiator at the front as an intake, using the bottom two 120mm slots. i will also have another 120mm fan above that taking up the third 120mm slot. i will have 3 120mm fans at the top as an exhaust as well. finally, i will have a rear exhaust fan, a side intake fan above the gpu(case mod) and a bottom intake fan.What is the make/model of your case?
The height available for an air cpu cooler will determine your best option.
If you have 160mm, there are a large number of coolers available.
Most all will fit 165mm.
Liquid cooling is really air cooling.
The main difference is where the heat exchange takes place.
H100 has two 120mm radiators.
That is the equivalent of twin radiators found in such air coolers as the scythe fuma II
https://www.newegg.com/scythe-scfm-2000/p/13C-0004-00085?&quicklink=true
I think this is an appropriate cooler for your cpu and budget.
For tops in cooling, look at the noctua NH-D15s with the equivalent of two 140mm radiators:
https://www.newegg.com/noctua-nh-d15s/p/N82E16835608072
Find your RGB bling elsewhere.
Mounting a liquid cooler gives you a catch 22 decision.
If you mount the radiator to draw in fresh air, the cpu will be cooled best but the heated air enters the case and impacts cooling of your graphics card and motherboard.
OTOH, if you mount it to exhaust your cpu will not be optimally cooled.
An air cooler is apt to be more reliable. It has no moving parts except the fan which is easily replaceable.
A liquid cooler has a mechanical pump which can fail or get clogged up.
While uncommon, liquid leaks can happen; an air cooler will not leak.
I did a google search for images using H100I leak" as a search argument.
https://www.google.com/search?q=H10...EjVkKHZ5dAbYQ_AUoAnoECB8QBA&biw=2040&bih=1271
There is a place for liquid cooling if you need exceptional cooling and a 360 size radiator.
Or, if you have a space constrained case.
I am in USA. Otherwise we might waste our time making recommendations all day for models that aren't even available or cost friendly in your region.
Ok.I am in USA
the system is fully assembled and i am currently using an old Intel Stock cooler. The temps are from 50-60 though, and i want them lowerOk.
Is this a system you are running NOW? If so, what are you currently using as a cooler? If not, when do you expect to have it assembled to the point where you NEED a cooler in order to complete the build?
Is there any chance of increasing the budget or is 75 bucks going to be the absolute most that could be put towards cooling, even if you had to push out the completion of the build a little ways?
i can push it to $135 if necessary.Is there any chance of increasing the budget or is 75 bucks going to be the absolute most that could be put towards cooling, even if you had to push out the completion of the build a little ways?
