Watercooling: Water flow sensor plug?
dicko_11_is
Commendable
Oct 10, 2017
90
Hi
Im purchasing parts for my 1st custom loop and ive got a temp sensor plug which is pretty straight forward but i want a water flow/pressure sensor too but dont like the big bulky turnstyle's etc. Is there such thing as a flow plug like the temp 1?
Anything subtle you know of for water flow?
Thanks for that. Still bigger than i was hoping for. I like how subtle a temp sensor plug is. I guess the way flow would read wouldnt work like that.
I think water temp sensor is a must. Do you think flow is necessary?
Yes. Once air is out of the system, the only thing you'll actually be able to see in the tubing is coolant. Without any air bubbles that are moving, you can't possibly tell the difference between stagnant coolant and moving coolant, there's no frame of reference. That's why the 'spinning wheel' is so popular, it's a visual representation of movement. If the wheel moves, the coolant is moving. You'd know immediately if there was a pump failure of any sort, either diaphragm or trapped air bubble etc as the wheel stops/slows.
During testing or benchmarking etc many use overlays when gaming, showing cpu/gpu temps. Easy visual to see. But most don't also want the overlay when not testing, just want nothing but the game on screen. The spinner proves coolant is moving, and having already established temps, all good, game on.
It's not a necessity, don't know of any AIO that has any meter as such, so there's a reliance on the pump to do its job. But as easy as it is to add on a custom loop, it'd be foolish not to have that peace of mind.
I tested an AIO that had one integrated in the top of the pump. Downside is that it often would stall out and stop moving even when coolant was still moving. The problem here is that AIO pumps typically don't generate a high enough flow to properly maintain a flow indicator based on fluid head pressure and when there is ample area for coolant to simply move around the meter paddles.
I like AIO's. I like the concept. I like the aesthetics. I hate the 'chincyness'. The only thing stopping me from custom loops is the price. Hard to justify a cooling solution that costs more than the $600 I paid for the entire pc.
So if actually going for a custom loop, my opinion is 'do it right', no half measures. There's plenty of space on a modern mid-atx tower to stick a flow meter, even unobtrusively, as a counter-balance to the pump. The trick is finding one that fits the build.
There aren't many flow meters that really work well or have the aesthetics that I would want. I'd rather have a non-intrusive digital version than mechanical.
That being said, you're right...watercooling is very expensive. The cooling loop for the Threadripper 2990WX that I just got done with was over $900 in watercooling parts alone.
Well to be fair, that Threadripper honestly will benefit from a good loop, it's not exactly a cheap setup nor easily thermally controlled, it's a freakin monster of a cpu. Most of the enthusiast class cpus are similar, and similarly expensive to setup right. Unlike your average lga115x or AM4 pc's where loops are at best an expensive, aesthetic hobby.
After digging around the net for an hour, I'm wondering exactly why there aren't really any digital flow meters, other than engineering ones or the Aquacomputers which are not standalone.
