Wavy Lines whyen playing games, Power supply failing?
Ashworth
9
Sorry if this is in the wrong place but can't seem to find a more appropriate forum.
Ok so recently when playing games my monitor produces wavy lines. It is a vga Acer 21.5ich 1920x1080 with 60HZ.
Apart from the lines on the screen games run perfect using a GTX 580 twin frozr 2 and my PSU doesn't run warm.
I have tried using 4 different monitors, all VGA as I've not access to digital, and they all produce the same lines.
I have also just put in my old 460 and the same lines appear when playing games.
I'm using as corsair tx650w that is about 1 year old. Is this a sign of my powersupply failing? Everything works perfectly, yet I see these lines on my monitor.
I also bought a new ssd about 2 weeks ago and didn't format old OS which I use for storage, could there be a driver clash or something?
I'm totally stuck, thanks for reading.
this is an example but not me:http://www.youtube.com/watch?v=FTk5buZwuXE
ADDITION:I have moved monitor away from speakers and is not near PSU cables so I don't think it could be interference as it only happens in games.
i think its a result of the gpu refresh rate and the monitors refresh rate being out of sync
can you pop into nvidia control panel and take a look at the settings to make sure they match with your monitor? see mine below:
additional: when you've tried other monitors have you used the same physical cable?
with that gpu you really should look to get a better display imho, see here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
after all, your gpu costs best part of 500 USD new, if not more
chaz
my refresh rate in nvidia control panel is 60hertz 32 bit colour at 1920x1080 and is the same with my monitors
and I tried several different vga and power cords
thanks for reply
this is something I just stumbled across on web...
"Yeah, the monitor works only by analog. So poor signal quality and/or interference is causing your issue; something that is not possible in the digital realm. With digital, it is either all or nothing (0s or 1s.)
My advice is to replace the vga cable to a better one and/or move pc away from any light source, cable, tv, phone or power lines running throughout the walls until the issue clears up."
http://www.sevenforums.com/graphic-cards/36813-wavy-lines-across-screen-like-refresh-rate-but-not.html
can you get to borrow a monitor with dvi/hdmi for an hour or so?
chaz
I have tried moving my monitor and different cables for no interference, but I get none when outside of games. I don't have access to a DVI and my case blocks the HDMI port in my 460...
latests official nvidia drivers, I didn't do anything special to delete drivers, I just ran the installer and it seemed to work
I don't think it has to do with the GPU. I just tried skyrim and I'm getting the wavey lines, but I'm still playing at 1920x1080 on ultra with 8xAA at 60fps and the game looks and runs amazingly. In light areas the lines are pretty much invisible but when you look up at the sky when its night you can see them. But it happens on every monitor I try.
I have just ordered a new PSU and DVI Monitor anyway.
i think it will be down the monitor and its vga connection with such a good card - I dont think it will be the PSU from what youve reported
keep us updated
chaz
where as drivers will "install" over and remove to some extent the old ones I am very cautious and always follow this process, call me fussy but I never had any issues - except for 10 years back when i didnt follow the process:
1. uninstall 3d drivers and physx via control panel/uninstall program
2. delete certain Nvidia folders in windows explorer (which folders will depend on your OS version)
3. device manager - uninstall GTX 460 drivers
4. reboot in safemode and run driversweep to remove traces of nvidia drivers left over
5. optional - i run cccleaner at this stage to remove crap from recycle bin
6. reboot in normal mode and install new driver
see this link for more info...
http://forums.nvidia.com/index.php?showtopic=169555
chaz
will do, thanks
The drivers for the 580 are exactly the same as the ones for the 460, so I'm not sure is necessary, I will do this after I get new monitor and psu, thanks
