Build Advice Way Past Due for a new PC...Build Help Needed
CMPhotography
21
I've been having some pretty regular errors with Windows 10. My current build says it isn't Windows 11 compatible.
Add to that the fact that it's been 8 years on this PC makes me think it would be better to build a new PC.
PC Use:
I'm a photographer so I mainly use the PC for Photoshop & Lightroom tasks. No gaming.
Requirements:
I want 1 SSD hard drive (at least 200GB) for the OS, a separate SSD (at least 125GB) for the Photoshop/Lightroom catalogs & cache. 2 separate hard drives (at least 1TB) for photos & storage.
I've been using a i5 3.5gig processor...probably want to go with an i7 since some Photoshop/Lightroom tasks take a bit to complete.
At least 16GB ram...thinking probably 32GB
At least a Nvidia GeForce GTX 1650 since I run an extra wide monitor @ 2560x1080
No need for audio as I'm running an external USB DAC.
Thoughts on PC component suggestions?
Totally unsure on motherboard/ram/cpu options since it's been quite a while since my last build.
How beefy of a power supply will I need?
My current case has the power supply on the bottom already so I'm hoping to reuse the case.
Hoping to keep this build under $1000.
Thanks!
Reactions: Why_Me
PCPartPicker Part List
CPU: Intel Core i7-13700 2.1 GHz 16-Core Processor ($359.99 @ Best Buy)
CPU Cooler: Thermalright Silver Soul 135 82 CFM CPU Cooler ($30.90 @ Amazon)
Motherboard: MSI MPG B760I EDGE WIFI Mini ITX LGA1700 Motherboard ($199.99 @ Newegg)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory ($99.99 @ Amazon)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($109.99 @ Newegg)
Video Card: MSI GAMING X GeForce RTX 3050 8GB 8 GB Video Card ($229.99 @ Newegg)
Case: Fractal Design Torrent Nano Mini ITX Tower Case ($105.99 @ Amazon)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Best Buy)
Case Fan: ADATA Vento 45.3 CFM 120 mm Fan ($13.99 @ Amazon)
Total: $1250.82
Generated by PCPartPicker 2023-06-01 13:07 EDT-0400
thats a bit over their budget.
Try this for under $1000:
Rather than small SSDs and some spinny drives, I gave you a a 1 TB SSD for boot and a 2TB for storage.
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor ($314.00 @ Amazon)
Motherboard: Gigabyte B650M K Micro ATX AM5 Motherboard ($124.99 @ Amazon)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory ($114.99 @ Corsair)
Storage: ADATA LEGEND 840 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($49.99 @ B&H)
Storage: Intel 670p 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($72.99 @ Newegg)
Video Card: ASRock Challenger D Radeon RX 6600 8 GB Video Card ($179.99 @ Newegg)
Case: DIYPC F2 MicroATX Mini Tower Case ($42.97 @ Newegg)
Power Supply: Antec NeoECO Gold ZEN 600 W 80+ Gold Certified ATX Power Supply ($76.98 @ Amazon)
Total: $976.90
Generated by PCPartPicker 2023-06-01 13:18 EDT-0400
Total: $1250.82
Go with the intel core i5 13500 13th gen, higher ghz and its like 100$ cheaper for 2 less cores.
PC Use:
Requirements:
Thanks!
CPU: *Intel Core i5-13500 2.5 GHz 14-Core Processor ($247.98 @ Newegg)
CPU Cooler: *Deepcool AK400 66.47 CFM CPU Cooler ($33.98 @ Newegg)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard ($147.62 @ Amazon)
Memory: *TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($58.99 @ Amazon)
Storage: *Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($109.99 @ Newegg)
Video Card: *MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card ($289.99 @ Lenovo)
Case: *Fractal Design Pop Air ATX Mid Tower Case ($79.99 @ B&H)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Best Buy)
Total: $1068.53
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2023-06-01 15:05 EDT-0400
Reactions: Anon#1234
What exact PSU and chassis do you have already? If the PSU is particularly old, might not be wise to re-use it, but a case is a case as long as the components fit.
CPU: Intel Core i7-13700F 2.1 GHz 16-Core Processor ($360.99 @ Amazon)
CPU Cooler: Thermalright Assassin X 90 SE 43 CFM CPU Cooler ($17.89 @ Amazon)
Motherboard: Gigabyte B760M DS3H AX Micro ATX LGA1700 Motherboard ($139.99 @ Amazon)
Memory: G.Skill Trident Z5 Neo 32 GB (2 x 16 GB) DDR5-5600 CL30 Memory ($85.00 @ Newegg)
Storage: Crucial P3 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($26.99 @ Amazon)
Storage: Crucial P3 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($87.99 @ Amazon)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case ($43.99 @ Amazon)
Power Supply: Thermaltake Toughpower GX2 600 W 80+ Gold Certified ATX Power Supply ($66.98 @ Amazon)
Total: $1009.81
Generated by PCPartPicker 2023-06-01 15:27 EDT-0400
What are your current parts?
I might guess that a i5 @3.5 might be a I5-4690 which has 4 threads and a passmark rating of 5573. That is when all threads are fully loaded.
The single thread rating is 2204.
I3/I5/I7/I9 no longer mean what they used to; namely how many cores and the presence of hyperthreading.
Today the designation is more of an overall capability.
For example, the current gen $127 I3-13100 is about 2x as strong with 8 threads and a rating of 15611/3767.
Next step up might be a $230 I5-13400 with 16 threads and a rating of 26026/3836.
Most any lga1700 motherboard will do.
Look for a B760 chipset and ddr5 capable. MATX size will usually be cheaper. $180 or so.
Photoshop can use lots of ram. I might suggest a kit of the new 24gb sticks for a total of 48gb:
SSD devices are now much cheaper. A 1tb m.2 pcie intel 670P or samsung 980 will cost $40 to $70 or so,
No need to fool with two drives. Space management is easier with one C drive.
Hard drives are good for bulk sequential storage; you probably have that covered.
If your app can use the CUDA cores of a graphics card for processing, GTX1650 will do.
What is the make/model of your current psu?
It might serve.The psu wattage you need for a system is mainly determined by the graphics card.
Here is a handy chart:
It shows 380W for a GTX1650.
Of more importance than wattage is the quality of the psu.
DO NOT buy a cheap psu.
Look for at least a 5 year warranty, 7 years or more is better.
It usually costs little more for a higher wattage unit.
Look at the pricing for a seasonic focus gm-550:
650w is only $10 or so more.
A psu will only use the power demanded of it, regardless of the max capability.
What is the make/model of your case?
Do you like it?
If so, you can very likely keep it.
Something like this?
CPU: Intel Core i7-13700F 2.1 GHz 16-Core Processor ($339.99 @ Best Buy)
CPU Cooler: Deepcool AG400 75.89 CFM CPU Cooler ($21.99 @ Amazon)
Motherboard: ASRock B760M Pro RS/D4 Micro ATX LGA1700 Motherboard ($129.99 @ Newegg)
Memory: OLOy Blade RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($51.00 @ Newegg)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($50.99 @ Amazon)
Video Card: Asus Phoenix Radeon RX 6400 4 GB Video Card ($97.49 @ Amazon)
Case: Deepcool CH370 MicroATX Mid Tower Case ($67.98 @ Newegg)
Power Supply: Super Flower Leadex III ARGB 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($84.99 @ Newegg Sellers)
Case Fan: Thermalright TL-C12C-S 66.17 CFM 120 mm Fans 3-Pack ($15.90 @ Amazon)
Total: $970.31
Generated by PCPartPicker 2023-06-02 07:03 EDT-0400
Currently, I'm running a Nvidia GeForce GTX 1650 for my ultra-wide monitor.
The suggested video cards vary quite a bit in price....help with sorting/ranking them?
Oh, and I'd like recommendations for a black small HTPC case since I'll take my current p/s, mb, ram & cpu and reformat my hard drive and build out a HTPC for media storage...
What form factor is your existing mobo (ATX, mATX, mITX)
What form factor is your existing PSU (ATX, SFX, SFX-L)
How many storage drive mounts do you need in the case? Just the one 3.5" drive?
Any dimensional limits in the space you plan putting the HTPC case?
