Way to put 3pin fan to PWM?
solomaniac85
127
Hello,
I have a gigabyte ud3h motherboard. It has only 4 pin fan connectors in an antec p280 case. I bought some corsair sp 120 fans for intake front fans. So I have a 3pin to molex adapter already. But the motherboard gives me a molex to 4pin adapter. Can I hook the fan up to the 3pin to molex and then the molex to 4pin and control the fans with pwm like speedfan? Thanks!
solomaniac85
127
Can you recommend any good fan controllers? Under 20$ if possible if its good for a bit more then post it. Thanks
