Way to use PCI card without desktop PC?
Thats really the only game in town, Magma actually patented that specific setup, and they are the only ones who make it. There are a couple of high end gaming Laptops that offer an external video card device, but otherwise thats prettymuch your only choice. And you can't use it with a Tablet, you need a laptop with a CardBus or ExpressCard slot (PCMCIA).
Patented? That's a bad news...
Maybe I have to build a mini ITX PC, still big, but much smaller than a desktop.
Yeah thats probably your best bet, but what type of PCI card do you need to run?
A camera controller: http://www.ebay.com/itm/Photometrics-PCI-3-3V-Board-PCI-Camera-Card-Coolsnap-/271693786355?
Ahh ok, Yeah there are a lot of small box miniITX builds you can do out there, that will handle that I am sure, and you can make portable. It won't be a laptop, but you won't be lugging a huge box either. Good luck!
Thank you but you're not that right, just type "itx board" in ebay and you will find many ITX mobo with PCI.
