[SOLVED] way too much input lag with vsync on and too much screen tearing with it off
a-guy
111
8
So i have a decent laptop it has a i7 7700HQ + 1050Ti + 16GB of ram and a 500 GB SSD but the laptop is also from dell so its more like sonic trying to run with one leg anyway i tried playing cs:go and the thing about the laptop is that it has insane screen tearing so naturally i tried vsync and after that i noticed i have a full half second of input lag and thats really bad for cs:go because at that point its hard to shoot the chickens running around and to be honest i have no idea how to make it run "smooth" i have tried all versions of vsync, fps limiter, undervolting the cpu and several things you can find on those youtube tutorials to make your pc run better except i didnt do anything to the registry because its risky and the laptop is already running at its worst after 2 years of use. Anyway if anyone has a clue how to get rid of screen tearing without using vsync please tell me.
boju
Ambassador
Try use fps_max command in csgo to 59 instead of using riva. Without riva and csgo set to 59, then try the vsync options i mentioned. Probably best use the game's own vsync as appose to Nvidia's.
a-guy
111
8
Try either Nvidia vsync / fast sync and the game's own vsync with Nvidia set to application control. Try each but limit fps to 59. See how you go.
So i tried the nvidia vsync only and honestly it probably made it worse, then i wanted to try the fast sync but i dont have that option so i cant try it and last i tried the nvidia application control + double buffer and so far that was the most playable option and the weird thing about it is that it feels like something is off but i cant tell what it is and when im looking around everything is blurry and if i look really close i can see that everything on the screen leaves "dust" behind it, is that normal? Other than that i can tell the input lag is there but its not that bad i guess i could get used to it after some time but if you got anymore ideas please tell me if you dont know anything else that could help i guess i could just mark your answer as best and leave it at that. Also i used rivatuner on all of those options and limited my fps to 59.
boju
Ambassador
a-guy
111
8
with the fps set to max 59 ingame, nvidia set to use 3D app settings and ingame vsync set to double buffer i cant see a single tear and the input lag is almost not there, the only bad thing i noticed is that when i alt+tab out of the game and back in i get really bad input lag for 3 seconds and that "dust" effect is almost gone too and i think thats about as good as it can get. Thank you for your help
