[SOLVED] Ways on how to ground yourself properly when building a PC?
Lil’bertz
321
5
18,785
Im going swap my prosessor(i3 6100) to another PC with an i5 6400 and the processors are compatible at their respective motherboards. what im worrying is that say that you should be grounded before replacing the processor. what best or easiest way to be grounded?
Sent from my iPad using Tapatalk
I have some remarks prepared I call it a canned rant
Canned Grounding Rant-
shut down system and remove side panel. with the power cable plugged into the PSU touch a bare unpainted metal area of the case. (my favorite spot is an unpainted screw securing the PSU) once you have grounded yourself you can unplug the computers power cable from the PSU and can touch the system.
if you move your feet, or shuffle in your chair, plug in the cord, reground yourself and unplug again.
end canned rant-
Assembly grounding:
plug in the power supply to the wall. you can touch an unpainted part of the PSU (insert an unpainted unfinished screw into the PSU mounting holes and touch the screw as a grounding point) once you have grounded yourself you...
end canned rant-
Assembly grounding:
plug in the power supply to the wall. you can touch an unpainted part of the PSU (insert an unpainted unfinished screw into the PSU mounting holes and touch the screw as a grounding point) once you have grounded yourself you can now touch and assemble the parts of the PC.
if you move your feet, or shuffle in your chair, reground yourself again.
install the CPU into the motherboard and the RAM into the slots.
install the cooler to the CPU. install the motherboard into the case.
secure the motherboard down with the screws, make sure you remove any unwanted/needed mounts before securing the motherboard.
unplug the PSU and ground yourself again. install the PSU into the case and secure with the 4 mounting screws.
plug in the power cord and ground yourself again from now on after grounding, unplug the power supply cord from the wall.
connect the power supply to the motherboard by the 24 pin and the AUX CPU power connector, install the GPU if one is selected, and install the drives with the supplied mounts in the case. connect the front panel connections to the case according to the manuals.
if there are any other peripherals, like wifi cards or sound card install and secure now. verify all power cables are connected to the motherboard and the GPU if needed.
the system can now be booted and the BIOS adjusted if needed (refer to motherboard manual) then an OS installed. when you are sure the system will need no more working/tinkering you can install the side panel and close the case. you have now assembled a PC.
end canned rant
hope this helps
end canned rant-
Assembly grounding:
end canned rant
hope this helps
can i use a stainless metal ruler or the metal part of the screwdriver to ground myself?
only if you are touching unpainted metal on the ruler or screwdriver.
just touching a ruler or a screwdriver will not ground you but using it as a conductor you can touch one end and the other end to the PSU and ground that way, but better to just touch the screw/PSU/grounding point with your hand.
the power supply through the cable is the ground point. its only grounded if the cable is plugged in.
I can't answer that because I don't know if it works with static electricity without ground. Yes I was talking about the US plug, I don't know about the UK plug.
Google just confirmed it, you need a ground to discharge.
