WD Black Hard Drive Noise
The results show that your HDD should be fine.
One thing you can do is to make sure the HDD is tightly fastened. Also, some users use different kinds of ant-acoustic/vibration screws/rubber grommets, isolation strips, etc.
D_Know_WD
I cannot listen at work, but I can confirm that many of the WD Black drives are much more audible than competitors' drives. I do not believe this represents a problem with the drive, and is a price to pay for the drive's speed. Remember that these drives have a five year warranty (other consumer drives are 2-3 years), so WD is obviously not concerned about it either.
I buy mostly WD Black mechanical drives myself. Some are noisier than others, but I don't recall one ever failing (I did get one DOA, promptly replaced).
Hi;
Thanks for the reply...
I ran the test, this is the result:
Model Number: WDC WD2002FAEX-007BA0
Firmware Number: 05.01D05
SMART Status: PASS
Test Result: PASS
