WD Caviar Blue Help
ChrisTsall99
700
Hello,
Some days ago I went to a store in order to buy a new HDD.
I asked for WD Caviar Blue 1TB 7200RPM the guy from the store told me that , they got it ...so I bought it and after I went home i saw the HDD and it had a blue thing that says Western Digital Blue PC Hard Drive... Here is my question , if i bought the WD Caviar Blue then it must say Western Digital Caviar Blue on the blue thing right? Should i give it back?
It's the same drive.
USAFRet
Hey there, ChrisTsall99!
@USAFRet is right. It's the same drive, the only difference is the fact that our newer WD Blue models are no longer called 'Caviar Blue'. You can check more about them on their official product page.
If you have any doubts regarding its authenticity, I'd strongly recommend you check the warranty of the HDD on our website.
Keep us posted if you have more concerns about! :)
Cheers,
SuperSoph_WD
ChrisTsall99
700
Thanks
