Heya,
I bought a brand new WD My Passport 1TB from Amazon. Tried it yesterday.
Updated the drive firmware using WD's FirmwareUpdater.
Also used WD Discovery software to check drive health - which passed successfully.
Plugged the external HDD via USB 3.0 cable to the USB 3.0 ports of my PC.
Tried 2 cables (the included short one, and another) and 3 different slots.
Also did the same with my new Asus Zenbook laptop.
Today I copied a large mass of files (pictures mostly and data) weighing up to 90.8 GB.
The drive copy speed started at around 90-100-110 then quickly dropped to the 60-ish area. Meaning 60 MB/s for the most part.
That's a lot slower than expected.
Took about 25 minutes to copy 90.8 GB without intrusions.
I decided to benchmark the drive, so I used CrystalDiskMark (latest ver) to check the drive - then compared it with images from reviews by Amazon buyers.
Got some really good drive speeds
135 Seq Q32T1 READ/ 122.5 WRITE MB/s.
128 Seq READ / 121 WRITE MB/s.
That's basically faster than the screenshots from Amazon reviews.
See image:
https://i.imgur.com/gxXOHn7.png
My benchmark scores are on the right.
I compared them to one of Amazon reviewers who reported high speeds.
So how come the actual write speeds are less than 50% ?
I noticed that yesterday - on my PC - which has a motherboard from 2011/12 - the USB 3.0 drive speeds hovered around 85/90-110 MBps when tranferring chunks of 20-30 GB. Most of the copy was at 90 MB/s.
So can it be that the larger the mass / more files - the slower the MB/s speed will be?
However my new Asus Zenbook Laptop's USB 3.0 was copying a big 90.8 gb (all the folders together in 1 go) at 60~ mbps.
It occasionally dropped to 20-40s or a even a few brief moments of 1 digit mbps/kbps.
See screenshot:
https://i.imgur.com/q6Tmasz.png
So, is this normal for an external drive of that type?
And how can you explain the big speed gap between the benchmark(s) and the actual work speed - when copying the real deal?
P.S: I even tried changing the drive Policy to "Better Performance" - but it didn't change a thing. So I took it back to "Quick Removal (Default)".
See image:
See screenshot:
