WD or Seagate Help me to choose
Vaip3r
63
I want to build a new pc and i do not know what i should choose between:
1st: Western Digital 1TB Caviar Blue WD10EZEX SATA III 7200rpm 64MB OR
2nd:Seagate 1TB Barracuda 7200.14 ST1000DM003 SATA III 7200rpm 64MB OR
3rd: Western Digital 1TB AV-GP WD10EURX SATA III 5400-7200rpm 64MB
1st: http://www.newegg.com/Product/Product.aspx?Item=9SIA2W00YU4026
2nd: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
3rd: http://www.newegg.com/Product/Product.aspx?Item=9SIA2W00YU4022
I want speed and stability.
Thanks.
Your first choice is the best. Caviar blue is western digital's bread & butter. Nearly as fast as their black edition especially with 64MB of cash ram at 7200rpm. Just a shorter warranty compared to the black editions.
And stay away from the av drive unless this is going into security camera recorder. They aren't designed for pc use and will not last long.
The seagate is a bit faster than the blue but really, either will be fine. If you have a favorite brand get it.
