My WD Passport has worked without fail for the past 4 years. Recently, when I was transferring files from the windows partition of my MacBook, the drive would disconnect in the middle of data transfers. Since then, even when using it on my normal Lenovo laptop with Windows 8, I have had errors transferring data. Now it is not read properly by my laptop, and using the WD Data LifeGuard Diagnostics says that it failed a SMART status.
When I connect it, the light turns on, I can hear it running, and nothing seems at fault - but obviously that doesn't mean something isn't wrong. Does anyone have any tips or tricks to try and fix this? I am running an extended test now and will have the results in a few hours. I have used a terabyte of the 2 available and would hate to lose all the data (photos from trips, etc).
Thank you!
Thank you!
