Hi there ShotTard,
Sorry that you are facing some issues with your WD drive.
Does the drive make any other unusual noises, except from the spinning one?
One thing you can do is to just test the drive with WD's Data Lifeguard Diagnostic tool(both short and extended tests), as iXeon has already suggested. If there's something wrong with the drive, my suggestion would be to back up the data stored on it.
Another thing you can try is to just re-seat the drive, attach it with different cables to another SATA port.
WD's Data Lifeguard Diagnostic tool:
http://products.wdc.com/support/kb.ashx?id=wKoFqz
Let me know how this goes,
D_Know_WD
