S Sal1ty05 Commendable May 2, 2021 34 2 1,535 Apr 10, 2023 #1 I have three WD sn850x m.2 My 2tb for the os temp is at 40 most the time and hits 54c on crystal disk stress test. Both my 1tb run around the same temp 45-48c. These two are next to each other under the heatsink. Are these temps good?
L Lafong Dignified Dec 2, 2021 6,072 1,816 15,690 Apr 10, 2023 #2 Excellent. Doesn't look like you'd even need the heatsinks. NVMe tends to run hotter than standard SSDs. Upvote 0 Downvote
S Sal1ty05 Commendable May 2, 2021 34 2 1,535 Apr 10, 2023 #3 Lafong said: Excellent. Doesn't look like you'd even need the heatsinks. NVMe tends to run hotter than standard SSDs. Click to expand... I came from the regular ssds so I wasn't sure on the m.2 versions. Upvote 0 Downvote
L Lafong Dignified Dec 2, 2021 6,072 1,816 15,690 Apr 10, 2023 #4 To give you an idea for comparison Right now in my room; 81 degrees F; 27 C; idling temps: 2 case fans running at 500 rpm WD Green 3.0 TB spinning hard drive; 37 Intel 660p NVMe data drive; 40 WD SN 770 NVMe boot drive; 42 Nothing with heatsinks. I used to have a standard SSD for a boot drive; that tended to be 3 or 4 degrees cooler than NVMe. Upvote 0 Downvote
S sonofjesse Distinguished Jul 27, 2016 1,144 255 19,790 Apr 11, 2023 #5 Temps are fine. I see more posts about temps for CPU/SSD, 99.99% of all posts your fine. Each part will have a rating by the MANF. https://documents.westerndigital.co...k-ssd/data-sheet-wd-black-sn850x-nvme-ssd.pdf If look at the WD spec sheet it says 0 to 85C. Your temp falls in that measurement so your good to go! my 850X 4TB is running at 36C idle in windows. Upvote 0 Downvote
Phaaze88 Titan Ambassador Dec 30, 2016 21,695 5,771 104,690 Apr 11, 2023 #6 There are 2 sensors, the memory and the controller. Everyone sees the memory. Use hwinfo to see both. Reactions: Lafong Upvote 0 Downvote
L Lafong Dignified Dec 2, 2021 6,072 1,816 15,690 Apr 11, 2023 #7 Controller temp is typically higher. HWInfo shows 3 temps on my WD NVMe drive and there is often a 20 degree range among the 3. I don't know, but I'd guess the throttling temp is based on the highest temp found on the drive? I recently ran a Crystal benchmark and the 3 max temps realized were 52, 73, and 47; without a heatsink. Upvote 0 Downvote
