WD10EZEX 1TB Hard Drive not Detected
Nanda_2
7
Hello!
So my new HDD which is Western Digital WD10EZEX is not detected in my PC.I am running Windows 10 Pro and I have a ECS H61-H2MV motherboard if that may be the case.
Thanks in advance for the help!
Open the start menu with the windows logo, search up disk management.
If it shows up there it will be in black with "unallocated space" just right click and pick new simple volume and follow that menu screen.
If it doesn't show up there then insure that you have plugged into the hard drive a sata cable for data which goes from the hard drive to the motherboard and also ensure that the power connector from the powersupply is connected.
