WD10EZEX power connector pinns broke
Oct 8, 2018
hi, the pinns from the powerconnector are all broken. first i thought that buying a new pcb whould be a solution, but after a bit research, it looks like it is impossible to switch the bios...at least for me. now i searching only the plastic connector with the data and power connectors, but after hours of searching i gave up. i found sata connectors, but no exact like this i need, sure i can solder any 15+7 conoctor to the pcb. but before i do that, i ask here if anyone now where to get that peace of plastik. the hd is a wd10EZEX-60ZF5A0 pcb: 2060-771824-006 rev a. i found that special pcb, for 29,99 eur, but 30 euro for only for the connector seems a bit overpriced. if it helps, the connector is an aphenol sata 00102463 .
