Yes... but it's means that both are the same SSD?.
It looks to me as if WD has created an artificial performance class by crippling the Black.You're rignt, but SN770 & SanDisk Extreme they have the same specifications, not the SN580.
The R/N (MVBSN1) is the same for SN740, SN770, SN580 and SD Extreme..., at least.![]()
The [SN580] drive uses WD’s proprietary controller technology under the SanDisk label. This four-channel controller is similar to what’s found on many of WD’s other NVMe SSDs, including the Green SN350, Blue SN500, Blue SN550, Blue SN570, and Black SN770. It appears to be running at a lower bus rate than the SN770, perhaps necessary to help differentiate the drives. The flash is the same 112-Layer TLC (BiCS5) used to good effect on the SN570 and SN770.
They engage in product segmentation with their proprietary controllers. So you have the Polaris Mp16 (x4 3.0 + 1200 MT/s) for SN350/SN550 variants and then the Mp16+ (x4 4.0 + 1600 MT/s) for the SN580/SN770. The SN580 is slower (4.15 GB/s v 5.15 GB/s) even with the same BiCS5, suggesting the SN580 is running the Mp16+ at 1200 MT/s but at x4 4.0 instead of the Mp16's x4 3.0. They could also pair it with the slower BiCS5 (1200 v 1600 MT/s) but it appears just to be set with a lower bus. They also play around with the interface for certain drives, so that's not set in stone (obviously).It looks to me as if WD has created an artificial performance class by crippling the Black.
