I have been using a pair of Devolo dLAN 500 AV Wireless+ for a couple of years and they work perfectly.In order to add a remote webcam to my setup I have purchased a Devolo dLAN 500 duo+ PLA and a Logitech c920 HD Pro webcam.In order to connect the webcam to the PLA I also ordered an adaptor, USB TO LAN RJ45 Ethernet 10Mb/100Mb Network Adapter (http://www.amazon.co.uk/dp/B000MHO3Q8/ref=pe_385721_37986871_TE_item).This was slightly damaged on arrival, but I think that I have been able to repair it.
The webcam was plugged in to a powered Belkin USB hub and that was plugged into the adaptor, which in turn was plugged into the PLA.My computer cannot see the webcam, although if I plug it directly into a USB socket on the computer it works correctly.I have also checked that the computer can see the new PLA using Devolo Cockpit, (the control panel software).
I have also tried plugging a powered USB drive into the PLA via the adaptor but this also cannot be seen by my computer.Another test I tried was to plug my laptop into the PLA using an Ethernet cable, after disabling the wireless connection, to see if could access the internet and my network drive , which it can.
All of this suggests these possibilities :-
1.The adaptor is faulty and the replacement will solve my problem when I receive it;
2.I need a different type of adaptor;
3.What I am trying is impossible.
Can anyone suggest how to solve my problem please?
Viv
Viv
