nike8
Hey, (im not sure this is the right section to post this) i have just set up my webcam to broadcast to my ip address through port 8080(using webcam xp), but it doesent seem to be working, i am able to broadcast to my lan address which is http://192.168.1.3:8080 but it is not being broadcasted to my ip address, do you think this could be because am behind a d-link router?
if so then is it possible to fix this? please explain simply because i am not a big computer wiz..!
Thanks.
Gothyk
7
Sounds like you need to set up port forwarding on your router.
Take a look on this website for a step-by-step guide on how to do that for your router to work with webcam xp:
http://www.portforward.com/
Hope this helps.
nike8
Thanks for the advise, although the problem still persists even after forwarding the ports.
Have any other ideas?
Thanks in advance.
