Ok so for the past month or so I have been having this problem and I figure its about time I figure it out. So whenever I go to shut down or restart my computer running vista it will say "shutting down" and it will get to about the point where the system would normally shut down but then I get a BSOD that lasts no more than half a second and the system reboots. This happens every single time. Keep in mind my system starts up just fine. So in order to turn my computer off I have been holding the power button down until It shuts off.
As of recently my system appears to no longer show the Blue screen when I go to shut my computer down, It will just reboot as if it is skipping the BSOD. This is unfortunate because I can't even read what the BSOD says anymore.
Any suggestions? I really don't want to have to install a fresh install of Vista because I would have alot of files to back up. From what I can gather this is not a hardware issue because my system has passed all the memory and hardware tests I throw at it.
I am also conserned this might be interfering with new installations of applications that require a system restart because it is not restarting correctly. I have even noticed that when I do a restart, or shut it down, the system won't save the new location of desktop icons if I move them.
I just want my computer to be able to go to sleep without having to pull the power on it 🙁
EDIT: Here are the system specs. I built this system myself about 2 months ago. It has been running just fine most of the time.
-4 gig 2x2gig chips of gskill pi ram
-Q9400 Quad Processor (OC to 3.6 and stable)
-ATI 4870, OC mem to 800 (stock it is 750mhz)
-500 gig harddrive Seagate
-650TX corsair PSU
LG optical drive
-650TX corsair PSU
LG optical drive
