Hello, so i recently cleaned my pc, with airduster, after i was done and plugged in the pc again, i got some weird fan noise. Sounds like a motor/scrapping noise, but it’s not scratching.
Bearing dry out aside, you have the rear case fan and the cpu cooler fan fighting against each other.
The rear fan is set to exhaust, so that's fine as is. The fan on the cpu cooler should be switched.Phaaze88, should i switch side on the cpu fan x)?
I've had that since 2020 but might be worth it,
