I recently installed a pair of dual nic HP SFP cards for my VMs. Initially, it was fine. Somehow, after a weekend reboot, one of the adapters no longer connects to the correct gateway or sub-net. I am baffled and really don't even understand what I am supposed to search in order to correct this.
You can see below that the adapter for Ethernet 9 is connecting to a different subnet for some inexplicable reason and has not attached a gateway. That Ethernet 9 is a physical adapter.
Keep in mind that Ethernet 8 and Ethernet 9 are on the same physical card. Please also keep in mind that my DHCP server lists the physical address of the adapter with a valid IP address (10.0.0.202).
I already broke the NIC team to try to figure this out. I have tried a simple trial and error to eliminate possible reasons. I have tried manually setting the gateway, subnet, IP and DNS but it doesn't ever "take". Other things I've tried out of desperation include swapping cables, switches, order of cable plugging, different cables in different ports, reboots etc.
Below is a screenshot of the ipconfig /all.
When I try to release #9, it tells me:
When I try to renew #9 it tells me:
I'm afraid that this has me baffled. Any wizards know what to make of this?
Code:
Windows IP Configuration
An error occurred while releasing interface Ethernet 9 : An address has not yet been associated with the network endpoint.
Code:
An error occurred while renewing interface Ethernet 9 : The name specified in the network control block (NCB) is in use on a remote adapter.
The NCB is the data.
