[SOLVED] Weird fan issue with NZXT Kraken X42
techflame700
Commendable
Nov 30, 2018
116
My NZXT Kraken X42’s fan won’t connect with the CAM software at all (it reads 0 RPM even though the fan is clearly spinning) also, the fan ramps up and down at random times. Thanks!
CPU: Intel i7 7700K
Motherboard: Gigabyte Z270XP SLI
Fan on radiator: stock fan plugged into the CPU_FAN header
In your AIO manual, read the following chapters and assemble your AIO as it is said and shown in there;
* POWERING THE FANS
* CONNECTING THE PUMP TACH
* CONNECTING THE SATA POWER CABLE
* CONNECTING USB CABLE
If you do all the above correctly, NZXT CAM should detect your rad fan and you can control it via NZXT CAM.
* POWERING THE FANS
Turns out I didn't plug the fans in correctly.
