Hi ,
I recently ear a loud noise coming from my pc while i was playing and i figured out it was my gpu fan (the noise is very loud i ear it with my headset with my music)
So i stress the gpu with 3Dmark and yes come again , the noise came from the fan to run at full speed and slow down , i think it's because the gpu reach 84° ( it's his limit so the fan goes crazy).
I clean it , try to put a 80mm fan below (only fan i can put it here ) , open the front case , all of that didn't work , my gpu doesn't even a 2 years old
Here what im talking ; https://streamable.com/iuh9d5
Here the result on 3DMARK
View: https://imgur.com/71u7ESL
for the temp
So i got few question is that temp is bad ?, should i use a custom curve fan for my gpu , because it never happen before
Here my configuration :
Ram : DDR4 3200Hz 16GO
HDD : 1To
Alimentation : 850W (Gold+)
CPU : I9-9900K not overclocked
SSD M.2 : 500GO +120 GO +1to
Boitier : Bequiet Silent Base 801 + 2 fan Pure Wings 2 120mm on the top
Carte mère : MSI MPG Z390 GAMING PRO CARBON
GPU : Gigabyte GeForce RTX 2080 Ti 11go not overclocked
Ventirad : Be Quiet! Dark Rock Pro 4
Thank for the help
for the temp
HDD : 1To
Thank for the help
