Weird FPS drops on my PC. Please help. :(
Lightness
51
Hello.
I recently bought a Zotac Nvidia GeForce GTX 970 Amp! Extreme Core Edition 4gb 256-bits (I read a lot of good reviews about it) to upgrade my old and good GTX 750 TI OC 2gb.
Alright. I've installed the card, installed the drivers and everything seemed to be perfect. I was happy, really happy. But not for long...
I wanted to test this new baby right away. So I opened GTA V. Put everything on Very High and went to test...
I expected something like this video:
https://www.youtube.com/watch?v=FGS7RjaY6v8
Well, it did not performed anything like the video. The MAX FPS was 60 and the average was 30~39. VSync was off so I can see the true performance of the card.
And it's not only on GTA V. Tom Clancy's The Division also have FPS drops. 60 to 51. 60 to 49... Basically every game that would run greatly on my PC with this card are having this "FPS drop issue"
I don't have a clue of what's going on and I need some help/advice please. I really don't know what's wrong.
My PC Specs are:
CPU: AMD FX-8320 3.5ghz
RAM: Kingston 1x8gb 1600mhz
HDD: Seagate 1tb model ST1000DM003
VGA: Zotac Nvidia GeForce GTX 970 Amp Extreme Core Edition
Mobo: M5A99FX PRO R2.0
PSU: Corsair 650W
I'm pretty sure that the CPU isn't overheating. So as GPU.
Any help/advice will be really appreciated.
Thank you. :)
GTX 970 has 3.5gb ram, how much did you use for GTAV? It says ingame when you're inside graphic settings tab. If you used more than 3.2 you might see stuttering and fps drops.
I had similar question with the same issue today already in this post:
http://www.tomshardware.co.uk/answers/id-3004913/zotac-geforce-gtx-970-memory-issue.html
Like is said there, use third party software to check your gpu ram consumption while ingame and take a screenshot of it or smth
It says on the card that it have 4gb. I don't get it. 3.5gb?
Oh well, I used 2.6gb more or less on GTA V...
Yes it's written 4gb but all 970 models have 0.5gb ram less than it's written. Ok then go ingame and look at how much % vram you gpu actually uses while you're gaming
check for gpu driver updates as well or try to rollback if you updated recently. It could be it
It's using less than 3gb on GTA V. I tried to change every single graphics options, even the texture.
My problem it is not stuttering. TheFPS is dropping ridiculously. 🙁
Even if I change the resolution to 720p... Did you see the video I posted? I was hoping to see something like that happening here...
Yeah. I tried to change but the FPS drops still happening. Not the entire time and not everywhere. It depends. For example if lots of cars/people appears.
Gta 5 is a cpu heavy game as well, have you tried looking at your usage on the cpu while playing. As for the 970 is does have 4gb of vram, you didn't get scammed for .5gb, the last .5 on the card just runs a slower bandwidth.
Did you Uninstall all your previous drivers before downloading the ones for the 970?
I used to play this game with my GTX 750 TI all the time and never had this FPS issue before. I used to play on high configurations and stuff.
Yes. Some more than others. GTA V, Wticher 3, Tom Clancy's The Division... I can play, but this FPS drops is kind annoying and disturbs the gameplay. Mainly in GTA.
So it doesn't happen in division or witcher3 ? or it does but not so often
activate shadowplay fps counter in your nvidia gexperience software and keep track of the fps while playing
Preferences tab, select ShadowPlay, choose the FPS Counter option, and select a location on your screen for the FPS counter.
I understand you used to play with the 750ti, I did as well and it was playable at a decent frame rate. My question was, did you Uninstall your drives before plugging in the 970 with a program like ddu. It could something as simple as a driver reinstall. The reason I brought up the cpu usage was because you said your fps drops when alot of people or objects on screen, if I'm not mistaken the cpu handles the physics for that game so it will hit your cpu harder and your fps would drop
true that, fx doesn't have that good single core performance, but 8320 should handle gta V pretty good since gta v can utilize more cores unlike wow for example; still worth checking with cpu-z running in background and logging
Of course I did uninstalled the drivers with DDU and did a clean install of the drivers. I tested some different versions of drivers to see if was that what was causing my FPS drops.
I will post the logs for the CPU and GPU here.
Is your cpu overclocked? You said it was at 3.5 so I would assume not, so heat shouldn't be an issue. Try checking your power settings in the control panel and make sure it's on high performance instead of balanced or power saver
Nope. I'm not overclockin anything.
Uhm... Isn't High Performance some kind of overclock?
The Forum don't let me post more than 67000 characters. Is there a way to upload the logs?
I'm gonna post the logs by parts. The GPU log first.
Date , GPU Core Clock [MHz] , GPU Memory Clock [MHz] , GPU Temperature [°C] , Fan Speed (%) [%] , Fan Speed (RPM) [RPM] , Memory Used [MB] , GPU Load [%] , Memory Controller Load [%] , Video Engine Load [%] , Bus Interface Load [%] , Power Consumption [% TDP] , PerfCap Reason [] , VDDC [V] ,
2016-03-17 09:50:53 , 988.0 , 1502.3 , 38.0 , 30 , 1080 , 180 , 0 , 0 , 0 , 0 , 28.6 , 16 , 1.0250 ,
2016-03-17 09:50:54 , 988.0 , 1502.3 , 38.0 , 30 , 1080 , 178 , 0 , 0 , 0 , 0 , 26.7 , 16 , 1.0250 ,
2016-03-17 09:50:55 , 988.0 , 1502.3 , 38.0 , 30 , 1079 , 178 , 0 , 0 , 0 , 0 , 26.6 , 16 , 1.0250 ,
2016-03-17 09:50:56 , 683.4 , 405.0 , 37.0 , 30 , 1087 , 178 , 0 , 2 , 0 , 0 , 11.1 , 16 , 0.8620 ,
2016-03-17 09:50:57 , 683.4 , 405.0 , 37.0 , 30 , 1092 , 178 , 0 , 1 , 0 , 0 , 10.8 , 16 , 0.8620 ,
2016-03-17 09:50:58 , 683.4 , 405.0 , 37.0 , 30 , 1094 , 181 , 3 , 3 , 0 , 0 , 11.0 , 16 , 0.8620 ,
2016-03-17 09:50:59 , 324.0 , 162.0 , 37.0 , 30 , 1096 , 180 , 7 , 9 , 0 , 0 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:51:00 , 324.0 , 162.0 , 37.0 , 30 , 1097 , 181 , 8 , 10 , 0 , 0 , 9.1 , 16 , 0.8620 ,
2016-03-17 09:51:01 , 162.0 , 162.0 , 37.0 , 30 , 1095 , 181 , 2 , 5 , 0 , 0 , 8.8 , 16 , 0.8620 ,
2016-03-17 09:51:02 , 162.0 , 162.0 , 37.0 , 30 , 1097 , 181 , 3 , 5 , 0 , 0 , 9.0 , 16 , 0.8620 ,
2016-03-17 09:51:03 , 162.0 , 162.0 , 37.0 , 30 , 1098 , 181 , 2 , 5 , 0 , 0 , 8.8 , 16 , 0.8620 ,
2016-03-17 09:51:04 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 181 , 2 , 5 , 0 , 0 , 8.8 , 16 , 0.8620 ,
2016-03-17 09:51:05 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 181 , 2 , 4 , 0 , 0 , 8.9 , 16 , 0.8620 ,
2016-03-17 09:51:06 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 181 , 2 , 5 , 0 , 0 , 8.9 , 16 , 0.8620 ,
2016-03-17 09:51:07 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 181 , 2 , 5 , 0 , 0 , 8.9 , 16 , 0.8620 ,
2016-03-17 09:51:08 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 181 , 2 , 4 , 0 , 0 , 8.8 , 16 , 0.8620 ,
2016-03-17 09:51:09 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 181 , 2 , 5 , 0 , 0 , 8.9 , 16 , 0.8620 ,
2016-03-17 09:51:10 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 181 , 2 , 5 , 0 , 0 , 8.9 , 16 , 0.8620 ,
2016-03-17 09:51:11 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 181 , 2 , 4 , 0 , 0 , 8.9 , 16 , 0.8620 ,
2016-03-17 09:51:12 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 181 , 2 , 5 , 0 , 0 , 8.9 , 16 , 0.8620 ,
2016-03-17 09:51:13 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 181 , 2 , 5 , 0 , 0 , 8.8 , 16 , 0.8620 ,
2016-03-17 09:51:14 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 181 , 2 , 5 , 0 , 0 , 9.0 , 16 , 0.8620 ,
2016-03-17 09:51:15 , 1227.7 , 1800.0 , 38.0 , 30 , 1091 , 191 , 0 , 0 , 0 , 0 , 28.7 , 16 , 1.0370 ,
2016-03-17 09:51:16 , 1227.7 , 1800.0 , 38.0 , 30 , 1087 , 221 , 5 , 2 , 0 , 1 , 29.0 , 16 , 1.0370 ,
2016-03-17 09:51:17 , 1227.7 , 1800.0 , 38.0 , 30 , 1084 , 221 , 0 , 0 , 0 , 0 , 28.7 , 16 , 1.0370 ,
2016-03-17 09:51:18 , 988.0 , 1502.3 , 38.0 , 30 , 1082 , 221 , 0 , 0 , 0 , 0 , 26.7 , 16 , 1.0250 ,
2016-03-17 09:51:19 , 988.0 , 1502.3 , 38.0 , 30 , 1081 , 221 , 0 , 0 , 0 , 0 , 26.8 , 16 , 1.0250 ,
2016-03-17 09:51:20 , 746.7 , 405.0 , 38.0 , 30 , 1088 , 221 , 0 , 1 , 0 , 0 , 11.5 , 16 , 0.8870 ,
2016-03-17 09:51:21 , 746.7 , 405.0 , 37.0 , 30 , 1092 , 221 , 2 , 2 , 0 , 0 , 10.9 , 16 , 0.8870 ,
2016-03-17 09:51:22 , 746.7 , 405.0 , 37.0 , 30 , 1094 , 229 , 12 , 10 , 0 , 3 , 11.9 , 16 , 0.8870 ,
2016-03-17 09:51:23 , 683.4 , 405.0 , 37.0 , 30 , 1095 , 229 , 13 , 10 , 0 , 3 , 11.6 , 16 , 0.8620 ,
2016-03-17 09:51:24 , 1227.7 , 1800.0 , 38.0 , 30 , 1088 , 253 , 0 , 0 , 0 , 0 , 28.6 , 16 , 1.0370 ,
2016-03-17 09:51:25 , 1227.7 , 1800.0 , 38.0 , 30 , 1083 , 262 , 2 , 0 , 0 , 1 , 29.1 , 16 , 1.0370 ,
2016-03-17 09:51:26 , 1227.7 , 1800.0 , 38.0 , 30 , 1082 , 270 , 2 , 1 , 0 , 1 , 29.1 , 16 , 1.0370 ,
2016-03-17 09:51:27 , 988.0 , 1502.3 , 39.0 , 30 , 1081 , 272 , 2 , 1 , 0 , 1 , 27.1 , 16 , 1.0250 ,
2016-03-17 09:51:28 , 988.0 , 1502.3 , 38.0 , 30 , 1081 , 272 , 2 , 1 , 0 , 1 , 27.0 , 16 , 1.0250 ,
2016-03-17 09:51:29 , 683.4 , 405.0 , 38.0 , 30 , 1083 , 272 , 3 , 3 , 0 , 1 , 18.9 , 16 , 0.8620 ,
2016-03-17 09:51:30 , 683.4 , 405.0 , 38.0 , 30 , 1092 , 272 , 7 , 5 , 0 , 3 , 11.1 , 16 , 0.8620 ,
2016-03-17 09:51:31 , 683.4 , 405.0 , 38.0 , 30 , 1095 , 272 , 6 , 4 , 0 , 3 , 11.0 , 16 , 0.8620 ,
2016-03-17 09:51:32 , 270.0 , 162.0 , 38.0 , 30 , 1096 , 272 , 14 , 13 , 0 , 3 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:51:33 , 270.0 , 162.0 , 38.0 , 30 , 1098 , 272 , 14 , 12 , 0 , 3 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:51:34 , 270.0 , 162.0 , 38.0 , 30 , 1100 , 272 , 14 , 13 , 0 , 3 , 9.7 , 16 , 0.8620 ,
2016-03-17 09:51:35 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 272 , 14 , 12 , 0 , 3 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:51:36 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 14 , 11 , 0 , 3 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:51:37 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 273 , 13 , 10 , 0 , 2 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:51:38 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:39 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:40 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:41 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:42 , 135.0 , 162.0 , 37.0 , 30 , 2206 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:43 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:44 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 273 , 0 , 3 , 0 , 0 , 8.4 , 16 , 0.8620 ,
2016-03-17 09:51:45 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:46 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:47 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:48 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:49 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.4 , 16 , 0.8620 ,
2016-03-17 09:51:50 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:51 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:52 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:53 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:54 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:55 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:56 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 273 , 0 , 3 , 0 , 0 , 8.5 , 16 , 0.8620 ,
2016-03-17 09:51:58 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 273 , 0 , 3 , 0 , 0 , 8.4 , 16 , 0.8620 ,
2016-03-17 09:51:59 , 135.0 , 162.0 , 37.0 , 30 , 1102 , 273 , 11 , 12 , 0 , 0 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:52:00 , 135.0 , 162.0 , 37.0 , 30 , 1103 , 273 , 11 , 12 , 0 , 0 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:52:01 , 135.0 , 162.0 , 37.0 , 30 , 1102 , 273 , 11 , 12 , 0 , 0 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:52:02 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 266 , 11 , 12 , 0 , 0 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:52:03 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 266 , 11 , 12 , 0 , 0 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:52:04 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 266 , 11 , 12 , 0 , 0 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:52:05 , 135.0 , 162.0 , 37.0 , 30 , 1102 , 266 , 11 , 12 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:52:06 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 266 , 11 , 12 , 0 , 0 , 9.3 , 16 , 0.8620 ,
2016-03-17 09:52:07 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 266 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:52:08 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 266 , 11 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:52:09 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 266 , 11 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:52:10 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 266 , 11 , 12 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:52:11 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 266 , 11 , 12 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:52:12 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 266 , 11 , 12 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:52:13 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 267 , 10 , 11 , 0 , 0 , 9.2 , 16 , 0.8620 ,
2016-03-17 09:52:14 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 267 , 13 , 15 , 0 , 0 , 9.9 , 16 , 0.8620 ,
2016-03-17 09:52:15 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 267 , 13 , 16 , 0 , 0 , 9.9 , 16 , 0.8620 ,
2016-03-17 09:52:16 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 267 , 14 , 16 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:17 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 268 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:18 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 268 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:19 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 268 , 16 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:20 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 268 , 15 , 17 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:21 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 268 , 15 , 17 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:22 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 268 , 16 , 16 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:23 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 299 , 13 , 13 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:24 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 299 , 16 , 16 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:25 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 299 , 16 , 17 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:26 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 299 , 16 , 17 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:27 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 299 , 16 , 17 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:28 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 299 , 15 , 17 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:29 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 299 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:30 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 299 , 15 , 17 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:31 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 299 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:32 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 299 , 14 , 16 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:33 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 299 , 14 , 16 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:34 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 300 , 14 , 16 , 0 , 0 , 10.3 , 16 , 0.8620 ,
2016-03-17 09:52:35 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 305 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:36 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 306 , 14 , 16 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:37 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 306 , 15 , 17 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:38 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 306 , 16 , 16 , 0 , 0 , 9.9 , 16 , 0.8620 ,
2016-03-17 09:52:39 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 307 , 14 , 14 , 0 , 0 , 9.8 , 16 , 0.8620 ,
2016-03-17 09:52:40 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 307 , 16 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:41 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 307 , 16 , 17 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:42 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 17 , 18 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:43 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 16 , 17 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:44 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 15 , 17 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:45 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 15 , 17 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:46 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 15 , 17 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:47 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 15 , 17 , 0 , 0 , 10.0 , 16 , 0.8620 ,
2016-03-17 09:52:48 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:49 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 15 , 17 , 0 , 0 , 10.1 , 16 , 0.8620 ,
2016-03-17 09:52:50 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:51 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:52 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:53 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 310 , 16 , 18 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:54 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 310 , 16 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:52:55 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 13 , 14 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:52:56 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:52:57 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:52:58 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:52:59 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:00 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:01 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:02 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:03 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:04 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:05 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:06 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:07 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:08 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 12 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:09 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:11 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:12 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:13 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:14 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:15 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:16 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:17 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:18 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:19 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:20 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:21 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:22 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:23 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:24 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 12 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:25 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:26 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:27 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:28 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:29 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:30 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 13 , 14 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:31 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:32 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 12 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:33 , 135.0 , 162.0 , 37.0 , 30 , 1102 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:34 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 12 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:35 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:36 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 ,
2016-03-17 09:53:37 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:38 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 13 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:39 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:40 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:41 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:42 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 13 , 14 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:43 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:44 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:45 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:46 , 135.0 , 162.0 , 36.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.7 , 16 , 0.8620 ,
2016-03-17 09:53:47 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 12 , 13 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:48 , 135.0 , 162.0 , 37.0 , 30 , 1102 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:49 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:50 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:51 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:52 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 13 , 14 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:53 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:54 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:53:55 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:56 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 12 , 13 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:53:57 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 12 , 13 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:58 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 12 , 13 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:53:59 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:54:00 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 13 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:54:01 , 135.0 , 162.0 , 37.0 , 30 , 1102 , 310 , 13 , 14 , 0 , 0 , 9.4 , 16 , 0.8620 ,
2016-03-17 09:54:02 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 13 , 14 , 0 , 0 , 9.8 , 16 , 0.8620 ,
2016-03-17 09:54:03 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:54:04 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 13 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:54:05 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:54:06 , 135.0 , 162.0 , 37.0 , 30 , 1101 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:54:07 , 135.0 , 162.0 , 37.0 , 30 , 1100 , 310 , 13 , 13 , 0 , 0 , 9.7 , 16 , 0.8620 ,
2016-03-17 09:54:08 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 310 , 12 , 13 , 0 , 0 , 9.6 , 16 , 0.8620 ,
2016-03-17 09:54:09 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 310 , 12 , 13 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:54:10 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 341 , 16 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:54:11 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 353 , 16 , 18 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:54:12 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 392 , 17 , 18 , 0 , 0 , 10.3 , 16 , 0.8620 ,
2016-03-17 09:54:13 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 392 , 17 , 18 , 0 , 0 , 10.3 , 16 , 0.8620 ,
2016-03-17 09:54:14 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 392 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:54:15 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 392 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:54:16 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 392 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:54:17 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 428 , 15 , 17 , 0 , 0 , 10.4 , 16 , 0.8620 ,
2016-03-17 09:54:18 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 441 , 15 , 17 , 0 , 0 , 10.4 , 16 , 0.8620 ,
2016-03-17 09:54:19 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 441 , 15 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:54:20 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 449 , 15 , 17 , 0 , 0 , 10.5 , 16 , 0.8620 ,
2016-03-17 09:54:21 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 458 , 17 , 18 , 0 , 0 , 10.4 , 16 , 0.8620 ,
2016-03-17 09:54:23 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 482 , 17 , 18 , 0 , 0 , 10.4 , 16 , 0.8620 ,
2016-03-17 09:54:24 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 492 , 15 , 17 , 0 , 0 , 10.3 , 16 , 0.8620 ,
2016-03-17 09:54:25 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 492 , 16 , 17 , 0 , 0 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:54:26 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 518 , 16 , 15 , 0 , 1 , 9.8 , 16 , 0.8620 ,
2016-03-17 09:54:27 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 532 , 14 , 14 , 0 , 0 , 9.5 , 16 , 0.8620 ,
2016-03-17 09:54:28 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 559 , 20 , 16 , 0 , 3 , 9.8 , 16 , 0.8620 ,
2016-03-17 09:54:29 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 610 , 21 , 18 , 0 , 2 , 10.5 , 16 , 0.8620 ,
2016-03-17 09:54:30 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 683 , 23 , 19 , 0 , 3 , 10.6 , 16 , 0.8620 ,
2016-03-17 09:54:31 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 756 , 23 , 19 , 0 , 2 , 10.5 , 16 , 0.8620 ,
2016-03-17 09:54:32 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 812 , 17 , 17 , 0 , 0 , 10.5 , 16 , 0.8620 ,
2016-03-17 09:54:33 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 869 , 20 , 18 , 0 , 1 , 10.4 , 16 , 0.8620 ,
2016-03-17 09:54:34 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 937 , 18 , 17 , 0 , 1 , 10.5 , 16 , 0.8620 ,
2016-03-17 09:54:35 , 135.0 , 162.0 , 37.0 , 30 , 1097 , 1007 , 25 , 19 , 0 , 4 , 10.7 , 16 , 0.8620 ,
2016-03-17 09:54:36 , 135.0 , 162.0 , 37.0 , 30 , 1094 , 1066 , 19 , 18 , 0 , 2 , 10.5 , 16 , 0.8620 ,
2016-03-17 09:54:37 , 135.0 , 162.0 , 37.0 , 30 , 1096 , 1158 , 22 , 19 , 0 , 3 , 10.5 , 16 , 0.8620 ,
2016-03-17 09:54:38 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 1243 , 21 , 18 , 0 , 2 , 10.2 , 16 , 0.8620 ,
2016-03-17 09:54:39 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 1319 , 21 , 18 , 0 , 2 , 10.6 , 16 , 0.8620 ,
2016-03-17 09:54:40 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 1398 , 20 , 18 , 0 , 1 , 10.4 , 16 , 0.8620 ,
2016-03-17 09:54:41 , 135.0 , 162.0 , 37.0 , 30 , 1099 , 1469 , 16 , 17 , 0 , 0 , 10.4 , 16 , 0.8620 ,
2016-03-17 09:54:42 , 135.0 , 162.0 , 37.0 , 30 , 1098 , 1564 , 18 , 18 , 0 , 1 , 10.4 , 16 , 0.8620 ,
2016-03-17 09:54:43 , 1265.6 , 1800.0 , 39.0 , 30 , 1088 , 1829 , 38 , 18 , 0 , 1 , 45.0 , 16 , 1.0560 ,
2016-03-17 09:54:44 , 1265.6 , 1800.0 , 40.0 , 30 , 1085 , 1835 , 32 , 17 , 0 , 0 , 44.0 , 16 , 1.0560 ,
2016-03-17 09:54:45 , 1265.6 , 1800.0 , 40.0 , 30 , 1084 , 1839 , 32 , 17 , 0 , 0 , 43.7 , 16 , 1.0560 ,
2016-03-17 09:54:46 , 1265.6 , 1800.0 , 40.0 , 30 , 1084 , 1845 , 31 , 16 , 0 , 0 , 42.8 , 16 , 1.0560 ,
2016-03-17 09:54:47 , 1265.6 , 1800.0 , 41.0 , 30 , 1083 , 1853 , 30 , 15 , 0 , 0 , 43.6 , 16 , 1.0560 ,
2016-03-17 09:54:48 , 1126.4 , 1800.0 , 41.0 , 30 , 1084 , 1861 , 33 , 15 , 0 , 0 , 41.8 , 16 , 1.0250 ,
2016-03-17 09:54:49 , 1126.4 , 1800.0 , 41.0 , 30 , 1084 , 1861 , 33 , 14 , 0 , 0 , 42.3 , 16 , 1.0250 ,
2016-03-17 09:54:50 , 1417.5 , 1800.0 , 43.0 , 30 , 1081 , 1879 , 42 , 20 , 0 , 1 , 60.2 , 4 , 1.2250 ,
2016-03-17 09:54:51 , 1417.5 , 1800.0 , 44.0 , 30 , 1081 , 1881 , 44 , 27 , 0 , 1 , 65.4 , 4 , 1.2250 ,
2016-03-17 09:54:52 , 1417.5 , 1800.0 , 45.0 , 30 , 1081 , 1890 , 43 , 25 , 0 , 2 , 66.8 , 4 , 1.2250 ,
2016-03-17 09:54:53 , 1417.5 , 1800.0 , 45.0 , 30 , 1080 , 1900 , 44 , 25 , 0 , 1 , 64.4 , 4 , 1.2250 ,
2016-03-17 09:54:54 , 1417.5 , 1800.0 , 45.0 , 31 , 1080 , 1907 , 38 , 22 , 0 , 1 , 61.4 , 4 , 1.2250 ,
2016-03-17 09:54:55 , 1417.5 , 1800.0 , 45.0 , 31 , 1080 , 1917 , 39 , 22 , 0 , 1 , 63.0 , 4 , 1.2250 ,
2016-03-17 09:54:56 , 1417.5 , 1800.0 , 46.0 , 31 , 1082 , 1933 , 42 , 23 , 0 , 2 , 62.6 , 4 , 1.2250 ,
2016-03-17 09:54:57 , 1417.5 , 1800.0 , 46.0 , 31 , 1083 , 1951 , 44 , 24 , 0 , 2 , 65.7 , 4 , 1.2250 ,
2016-03-17 09:54:58 , 1417.5 , 1800.0 , 47.0 , 31 , 1083 , 1956 , 45 , 25 , 0 , 2 , 65.5 , 4 , 1.2250 ,
2016-03-17 09:54:59 , 1417.5 , 1800.0 , 47.0 , 31 , 1085 , 1961 , 42 , 23 , 0 , 1 , 62.7 , 4 , 1.2250 ,
2016-03-17 09:55:00 , 1417.5 , 1800.0 , 47.0 , 32 , 1085 , 1963 , 43 , 25 , 0 , 1 , 65.0 , 4 , 1.2250 ,
2016-03-17 09:55:01 , 1417.5 , 1800.0 , 47.0 , 32 , 1088 , 1969 , 41 , 25 , 0 , 1 , 63.3 , 4 , 1.2250 ,
2016-03-17 09:55:02 , 1417.5 , 1800.0 , 48.0 , 32 , 1092 , 1979 , 44 , 26 , 0 , 1 , 66.5 , 4 , 1.2250 ,
2016-03-17 09:55:03 , 1417.5 , 1800.0 , 48.0 , 32 , 1097 , 1985 , 43 , 26 , 0 , 1 , 63.9 , 4 , 1.2250 ,
2016-03-17 09:55:04 , 1417.5 , 1800.0 , 48.0 , 32 , 1104 , 1985 , 41 , 25 , 0 , 1 , 65.0 , 4 , 1.2250 ,
2016-03-17 09:55:05 , 1417.5 , 1800.0 , 48.0 , 32 , 1110 , 1985 , 42 , 25 , 0 , 1 , 66.7 , 4 , 1.2250 ,
2016-03-17 09:55:06 , 1417.5 , 1800.0 , 48.0 , 33 , 1116 , 1992 , 43 , 25 , 0 , 1 , 66.8 , 4 , 1.2250 ,
2016-03-17 09:55:07 , 1417.5 , 1800.0 , 49.0 , 33 , 1122 , 1995 , 42 , 26 , 0 , 1 , 65.5 , 4 , 1.2250 ,
2016-03-17 09:55:08 , 1417.5 , 1800.0 , 49.0 , 33 , 1128 , 1996 , 44 , 25 , 0 , 2 , 68.5 , 4 , 1.2250 ,
2016-03-17 09:55:09 , 1417.5 , 1800.0 , 50.0 , 33 , 1134 , 1997 , 49 , 26 , 0 , 2 , 72.5 , 4 , 1.2250 ,
2016-03-17 09:55:10 , 1417.5 , 1800.0 , 49.0 , 33 , 1143 , 2003 , 41 , 24 , 0 , 1 , 64.3 , 4 , 1.2250 ,
2016-03-17 09:55:11 , 1417.5 , 1800.0 , 49.0 , 33 , 1149 , 2010 , 41 , 24 , 0 , 1 , 65.4 , 4 , 1.2250 ,
2016-03-17 09:55:12 , 1417.5 , 1800.0 , 50.0 , 34 , 1155 , 2024 , 45 , 26 , 0 , 2 , 64.1 , 4 , 1.2250 ,
2016-03-17 09:55:13 , 1417.5 , 1800.0 , 49.0 , 34 , 1161 , 2032 , 41 , 24 , 0 , 1 , 64.1 , 4 , 1.2250 ,
2016-03-17 09:55:14 , 1417.5 , 1800.0 , 50.0 , 34 , 1165 , 2044 , 42 , 23 , 0 , 1 , 65.2 , 4 , 1.2250 ,
2016-03-17 09:55:15 , 1417.5 , 1800.0 , 50.0 , 34 , 1169 , 2053 , 45 , 24 , 0 , 2 , 66.4 , 4 , 1.2250 ,
2016-03-17 09:55:16 , 1417.5 , 1800.0 , 51.0 , 34 , 1175 , 2060 , 45 , 25 , 0 , 2 , 66.0 , 4 , 1.2250 ,
2016-03-17 09:55:17 , 1417.5 , 1800.0 , 51.0 , 34 , 1181 , 2072 , 41 , 21 , 0 , 1 , 63.2 , 4 , 1.2250 ,
2016-03-17 09:55:18 , 1417.5 , 1800.0 , 50.0 , 34 , 1187 , 2084 , 42 , 24 , 0 , 2 , 63.3 , 4 , 1.2250 ,
2016-03-17 09:55:19 , 1417.5 , 1800.0 , 51.0 , 34 , 1190 , 2112 , 45 , 25 , 0 , 2 , 68.2 , 4 , 1.2250 ,
2016-03-17 09:55:20 , 1417.5 , 1800.0 , 51.0 , 34 , 1195 , 2126 , 42 , 24 , 0 , 2 , 63.7 , 4 , 1.2250 ,
2016-03-17 09:55:21 , 1417.5 , 1800.0 , 51.0 , 35 , 1199 , 2133 , 42 , 24 , 0 , 2 , 65.6 , 4 , 1.2250 ,
2016-03-17 09:55:22 , 1417.5 , 1800.0 , 51.0 , 35 , 1202 , 2144 , 43 , 25 , 0 , 2 , 64.9 , 4 , 1.2250 ,
2016-03-17 09:55:23 , 1417.5 , 1800.0 , 51.0 , 35 , 1205 , 2144 , 42 , 24 , 0 , 2 , 64.0 , 4 , 1.2250 ,
2016-03-17 09:55:24 , 1417.5 , 1800.0 , 51.0 , 35 , 1209 , 2144 , 40 , 22 , 0 , 2 , 62.1 , 4 , 1.2250 ,
2016-03-17 09:55:25 , 1417.5 , 1800.0 , 51.0 , 35 , 1213 , 2145 , 40 , 22 , 0 , 2 , 61.9 , 4 , 1.2250 ,
2016-03-17 09:55:26 , 1417.5 , 1800.0 , 51.0 , 35 , 1213 , 2154 , 37 , 21 , 0 , 2 , 61.0 , 4 , 1.2250 ,
2016-03-17 09:55:27 , 1417.5 , 1800.0 , 51.0 , 35 , 1218 , 2158 , 35 , 20 , 0 , 2 , 60.8 , 4 , 1.2250 ,
2016-03-17 09:55:28 , 1417.5 , 1800.0 , 51.0 , 35 , 1218 , 2210 , 36 , 19 , 0 , 2 , 59.2 , 4 , 1.2250 ,
2016-03-17 09:55:29 , 1417.5 , 1800.0 , 52.0 , 35 , 1221 , 2227 , 40 , 22 , 0 , 2 , 61.8 , 4 , 1.2250 ,
2016-03-17 09:55:30 , 1417.5 , 1800.0 , 52.0 , 35 , 1223 , 2253 , 41 , 23 , 0 , 2 , 61.8 , 4 , 1.2250 ,
2016-03-17 09:55:31 , 1417.5 , 1800.0 , 52.0 , 35 , 1223 , 2268 , 38 , 22 , 0 , 2 , 62.3 , 4 , 1.2250 ,
2016-03-17 09:55:32 , 1417.5 , 1800.0 , 52.0 , 35 , 1223 , 2311 , 39 , 22 , 0 , 2 , 62.4 , 4 , 1.2250 ,
2016-03-17 09:55:33 , 1417.5 , 1800.0 , 52.0 , 35 , 1226 , 2345 , 36 , 21 , 0 , 2 , 57.5 , 4 , 1.2250 ,
2016-03-17 09:55:35 , 1417.5 , 1800.0 , 52.0 , 35 , 1231 , 2361 , 41 , 24 , 0 , 2 , 63.3 , 4 , 1.2250 ,
2016-03-17 09:55:36 , 1417.5 , 1800.0 , 53.0 , 35 , 1233 , 2410 , 43 , 25 , 0 , 2 , 64.0 , 4 , 1.2250 ,
2016-03-17 09:55:37 , 1417.5 , 1800.0 , 53.0 , 35 , 1234 , 2455 , 40 , 24 , 0 , 2 , 63.6 , 4 , 1.2250 ,
2016-03-17 09:55:38 , 1417.5 , 1800.0 , 52.0 , 36 , 1236 , 2506 , 35 , 20 , 0 , 2 , 59.4 , 4 , 1.2250 ,
2016-03-17 09:55:39 , 1417.5 , 1800.0 , 53.0 , 36 , 1237 , 2527 , 40 , 24 , 0 , 2 , 62.1 , 4 , 1.2250 ,
2016-03-17 09:55:40 , 1417.5 , 1800.0 , 53.0 , 36 , 1240 , 2556 , 37 , 22 , 0 , 2 , 62.2 , 4 , 1.2250 ,
2016-03-17 09:55:41 , 1417.5 , 1800.0 , 53.0 , 36 , 1243 , 2590 , 42 , 25 , 0 , 2 , 64.3 , 4 , 1.2250 ,
2016-03-17 09:55:42 , 1417.5 , 1800.0 , 53.0 , 36 , 1246 , 2610 , 41 , 25 , 0 , 2 , 64.5 , 4 , 1.2250 ,
2016-03-17 09:55:43 , 1417.5 , 1800.0 , 53.0 , 36 , 1246 , 2647 , 39 , 24 , 0 , 2 , 61.0 , 4 , 1.2250 ,
2016-03-17 09:55:44 , 1417.5 , 1800.0 , 53.0 , 36 , 1250 , 2677 , 35 , 20 , 0 , 2 , 58.0 , 4 , 1.2250 ,
2016-03-17 09:55:45 , 1417.5 , 1800.0 , 53.0 , 36 , 1252 , 2715 , 37 , 21 , 0 , 2 , 60.4 , 4 , 1.2250 ,
2016-03-17 09:55:46 , 1417.5 , 1800.0 , 53.0 , 36 , 1253 , 2752 , 40 , 22 , 0 , 2 , 62.8 , 4 , 1.2250 ,
2016-03-17 09:55:47 , 1417.5 , 1800.0 , 53.0 , 36 , 1259 , 2780 , 35 , 20 , 0 , 2 , 59.8 , 4 , 1.2250 ,
2016-03-17 09:55:48 , 1417.5 , 1800.0 , 53.0 , 36 , 1261 , 2802 , 35 , 20 , 0 , 2 , 61.0 , 4 , 1.2250 ,
2016-03-17 09:55:49 , 1417.5 , 1800.0 , 54.0 , 36 , 1262 , 2824 , 37 , 21 , 0 , 1 , 64.4 , 4 , 1.2250 ,
2016-03-17 09:55:50 , 1417.5 , 1800.0 , 54.0 , 36 , 1262 , 2833 , 42 , 25 , 0 , 2 , 65.2 , 4 , 1.2250 ,
2016-03-17 09:55:51 , 1417.5 , 1800.0 , 54.0 , 36 , 1264 , 2849 , 38 , 22 , 0 , 2 , 62.1 , 4 , 1.2250 ,
2016-03-17 09:55:52 , 1417.5 , 1800.0 , 53.0 , 36 , 1264 , 2875 , 36 , 20 , 0 , 1 , 58.8 , 4 , 1.2250 ,
2016-03-17 09:55:53 , 1417.5 , 1800.0 , 53.0 , 36 , 1266 , 2895 , 37 , 20 , 0 , 1 , 59.9 , 4 , 1.2250 ,
2016-03-17 09:55:54 , 1417.5 , 1800.0 , 54.0 , 36 , 1269 , 2919 , 42 , 24 , 0 , 2 , 64.0 , 4 , 1.2250 ,
2016-03-17 09:55:55 , 1417.5 , 1800.0 , 53.0 , 36 , 1271 , 2952 , 35 , 19 , 0 , 2 , 58.8 , 4 , 1.2250 ,
2016-03-17 09:55:56 , 1417.5 , 1800.0 , 54.0 , 37 , 1273 , 2974 , 42 , 22 , 0 , 2 , 58.2 , 4 , 1.2250 ,
2016-03-17 09:55:57 , 1417.5 , 1800.0 , 54.0 , 37 , 1277 , 2964 , 37 , 20 , 0 , 2 , 60.9 , 4 , 1.2250 ,
2016-03-17 09:55:58 , 1417.5 , 1800.0 , 54.0 , 37 , 1273 , 2963 , 38 , 22 , 0 , 2 , 62.0 , 4 , 1.2250 ,
2016-03-17 09:55:59 , 1417.5 , 1800.0 , 54.0 , 37 , 1242 , 2976 , 38 , 20 , 0 , 3 , 62.6 , 4 , 1.2250 ,
2016-03-17 09:56:00 , 1417.5 , 1800.0 , 54.0 , 37 , 1229 , 2988 , 35 , 19 , 0 , 2 , 58.5 , 4 , 1.2250 ,
2016-03-17 09:56:01 , 1417.5 , 1800.0 , 54.0 , 37 , 1232 , 2988 , 35 , 18 , 0 , 2 , 59.2 , 4 , 1.2250 ,
2016-03-17 09:56:02 , 1417.5 , 1800.0 , 55.0 , 37 , 1237 , 2982 , 41 , 24 , 0 , 2 , 63.8 , 4 , 1.2250 ,
2016-03-17 09:56:03 , 1417.5 , 1800.0 , 55.0 , 37 , 1248 , 2983 , 42 , 25 , 0 , 2 , 64.6 , 4 , 1.2250 ,
2016-03-17 09:56:04 , 1417.5 , 1800.0 , 55.0 , 37 , 1260 , 2985 , 43 , 26 , 0 , 2 , 66.0 , 4 , 1.2250 ,
2016-03-17 09:56:05 , 1417.5 , 1800.0 , 55.0 , 37 , 1273 , 2980 , 41 , 25 , 0 , 1 , 63.7 , 4 , 1.2250 ,
2016-03-17 09:56:06 , 1417.5 , 1800.0 , 54.0 , 37 , 1282 , 2982 , 38 , 21 , 0 , 2 , 61.1 , 4 , 1.2250 ,
2016-03-17 09:56:07 , 1417.5 , 1800.0 , 54.0 , 37 , 1289 , 2977 , 35 , 19 , 0 , 2 , 54.3 , 4 , 1.2250 ,
2016-03-17 09:56:08 , 1417.5 , 1800.0 , 55.0 , 37 , 1296 , 2976 , 38 , 22 , 0 , 2 , 61.3 , 4 , 1.2250 ,
2016-03-17 09:56:09 , 1417.5 , 1800.0 , 55.0 , 37 , 1301 , 2980 , 42 , 23 , 0 , 2 , 63.3 , 4 , 1.2250 ,
2016-03-17 09:56:10 , 1417.5 , 1800.0 , 55.0 , 37 , 1302 , 2993 , 37 , 21 , 0 , 2 , 63.9 , 4 , 1.2250 ,
2016-03-17 09:56:11 , 1417.5 , 1800.0 , 55.0 , 37 , 1302 , 3004 , 43 , 24 , 0 , 2 , 67.4 , 4 , 1.2250 ,
2016-03-17 09:56:12 , 1417.5 , 1800.0 , 55.0 , 37 , 1305 , 3007 , 39 , 22 , 0 , 2 , 64.7 , 4 , 1.2250 ,
2016-03-17 09:56:13 , 1417.5 , 1800.0 , 55.0 , 37 , 1305 , 3017 , 41 , 23 , 0 , 2 , 63.2 , 4 , 1.2250 ,
2016-03-17 09:56:14 , 1417.5 , 1800.0 , 55.0 , 37 , 1305 , 3031 , 40 , 19 , 0 , 2 , 63.2 , 4 , 1.2250 ,
2016-03-17 09:56:15 , 1417.5 , 1800.0 , 55.0 , 38 , 1310 , 3038 , 39 , 21 , 0 , 2 , 61.9 , 4 , 1.2250 ,
2016-03-17 09:56:16 , 1417.5 , 1800.0 , 55.0 , 38 , 1310 , 3040 , 37 , 20 , 0 , 2 , 59.8 , 4 , 1.2250 ,
2016-03-17 09:56:17 , 1417.5 , 1800.0 , 56.0 , 38 , 1309 , 3035 , 38 , 20 , 0 , 2 , 64.4 , 4 , 1.2250 ,
2016-03-17 09:56:18 , 1417.5 , 1800.0 , 56.0 , 38 , 1312 , 3043 , 39 , 21 , 0 , 2 , 63.2 , 4 , 1.2250 ,
2016-03-17 09:56:19 , 1417.5 , 1800.0 , 55.0 , 38 , 1315 , 3038 , 39 , 22 , 0 , 2 , 63.6 , 4 , 1.2250 ,
2016-03-17 09:56:20 , 1417.5 , 1800.0 , 55.0 , 38 , 1314 , 3043 , 35 , 19 , 0 , 2 , 60.2 , 4 , 1.2250 ,
2016-03-17 09:56:21 , 1417.5 , 1800.0 , 55.0 , 38 , 1315 , 3042 , 36 , 19 , 0 , 2 , 59.8 , 4 , 1.2250 ,
2016-03-17 09:56:22 , 1417.5 , 1800.0 , 55.0 , 38 , 1317 , 3043 , 34 , 19 , 0 , 2 , 60.9 , 4 , 1.2250 ,
2016-03-17 09:56:23 , 1417.5 , 1800.0 , 56.0 , 38 , 1316 , 3044 , 43 , 25 , 0 , 2 , 63.0 , 4 , 1.2250 ,
2016-03-17 09:56:24 , 1417.5 , 1800.0 , 56.0 , 38 , 1319 , 3046 , 44 , 25 , 0 , 2 , 65.3 , 4 , 1.2250 ,
2016-03-17 09:56:25 , 1417.5 , 1800.0 , 56.0 , 38 , 1321 , 3032 , 42 , 23 , 0 , 2 , 64.1 , 4 , 1.2250 ,
2016-03-17 09:56:26 , 1417.5 , 1800.0 , 56.0 , 38 , 1323 , 3035 , 39 , 21 , 0 , 2 , 61.0 , 4 , 1.2250 ,
2016-03-17 09:56:27 , 1417.5 , 1800.0 , 55.0 , 38 , 1323 , 3035 , 36 , 18 , 0 , 2 , 59.6 , 4 , 1.2250 ,
2016-03-17 09:56:28 , 1417.5 , 1800.0 , 56.0 , 38 , 1324 , 3039 , 36 , 20 , 0 , 2 , 61.1 , 4 , 1.2250 ,
2016-03-17 09:56:29 , 1417.5 , 1800.0 , 56.0 , 38 , 1323 , 3032 , 44 , 25 , 0 , 2 , 64.5 , 4 , 1.2250 ,
2016-03-17 09:56:30 , 1417.5 , 1800.0 , 56.0 , 38 , 1325 , 3032 , 39 , 21 , 0 , 2 , 61.1 , 4 , 1.2250 ,
2016-03-17 09:56:31 , 1417.5 , 1800.0 , 56.0 , 38 , 1326 , 3033 , 42 , 23 , 0 , 2 , 63.1 , 4 , 1.2250 ,
2016-03-17 09:56:32 , 1417.5 , 1800.0 , 56.0 , 38 , 1327 , 3035 , 42 , 23 , 0 , 3 , 64.3 , 4 , 1.2250 ,
2016-03-17 09:56:33 , 1417.5 , 1800.0 , 57.0 , 38 , 1329 , 3034 , 45 , 25 , 0 , 2 , 66.9 , 4 , 1.2250 ,
2016-03-17 09:56:34 , 1417.5 , 1800.0 , 57.0 , 38 , 1332 , 3040 , 43 , 24 , 0 , 3 , 70.1 , 4 , 1.2250 ,
2016-03-17 09:56:35 , 1417.5 , 1800.0 , 57.0 , 38 , 1334 , 3037 , 44 , 25 , 0 , 2 , 67.2 , 4 , 1.2250 ,
2016-03-17 09:56:36 , 1417.5 , 1800.0 , 57.0 , 38 , 1335 , 3038 , 45 , 25 , 0 , 2 , 66.5 , 4 , 1.2250 ,
2016-03-17 09:56:37 , 1417.5 , 1800.0 , 57.0 , 39 , 1338 , 3035 , 44 , 26 , 0 , 2 , 68.2 , 4 , 1.2250 ,
2016-03-17 09:56:38 , 1417.5 , 1800.0 , 57.0 , 39 , 1342 , 3038 , 44 , 26 , 0 , 2 , 67.3 , 4 , 1.2250 ,
2016-03-17 09:56:39 , 1417.5 , 1800.0 , 57.0 , 39 , 1347 , 3034 , 44 , 25 , 0 , 2 , 64.8 , 4 , 1.2250 ,
2016-03-17 09:56:40 , 1417.5 , 1800.0 , 57.0 , 39 , 1349 , 3029 , 40 , 23 , 0 , 2 , 65.0 , 4 , 1.2250 ,
2016-03-17 09:56:41 , 1417.5 , 1800.0 , 56.0 , 39 , 1353 , 3034 , 34 , 18 , 0 , 3 , 60.2 , 4 , 1.2250 ,
2016-03-17 09:56:42 , 1417.5 , 1800.0 , 56.0 , 39 , 1356 , 3041 , 37 , 19 , 0 , 3 , 60.1 , 4 , 1.2250 ,
2016-03-17 09:56:43 , 1417.5 , 1800.0 , 58.0 , 39 , 1355 , 3047 , 49 , 27 , 0 , 2 , 71.7 , 4 , 1.2250 ,
2016-03-17 09:56:44 , 1417.5 , 1800.0 , 59.0 , 39 , 1356 , 3047 , 48 , 26 , 0 , 1 , 75.4 , 4 , 1.2250 ,
2016-03-17 09:56:45 , 1417.5 , 1800.0 , 59.0 , 39 , 1357 , 3042 , 53 , 28 , 0 , 2 , 79.2 , 4 , 1.2250 ,
2016-03-17 09:56:47 , 1417.5 , 1800.0 , 59.0 , 39 , 1361 , 3045 , 51 , 28 , 0 , 1 , 78.0 , 4 , 1.2250 ,
2016-03-17 09:56:48 , 1417.5 , 1800.0 , 59.0 , 40 , 1367 , 3040 , 51 , 27 , 0 , 1 , 71.8 , 4 , 1.2250 ,
2016-03-17 09:56:49 , 1417.5 , 1800.0 , 59.0 , 40 , 1373 , 3042 , 47 , 24 , 0 , 1 , 73.6 , 4 , 1.2250 ,
2016-03-17 09:56:50 , 1417.5 , 1800.0 , 59.0 , 40 , 1380 , 3043 , 44 , 22 , 0 , 1 , 68.8 , 4 , 1.2250 ,
2016-03-17 09:56:51 , 1417.5 , 1800.0 , 58.0 , 40 , 1386 , 3044 , 41 , 22 , 0 , 1 , 64.2 , 4 , 1.2250 ,
2016-03-17 09:56:52 , 1417.5 , 1800.0 , 58.0 , 40 , 1392 , 3046 , 39 , 22 , 0 , 1 , 67.6 , 4 , 1.2250 ,
2016-03-17 09:56:53 , 1417.5 , 1800.0 , 58.0 , 40 , 1397 , 3045 , 38 , 22 , 0 , 0 , 65.6 , 4 , 1.2250 ,
2016-03-17 09:56:54 , 135.0 , 162.0 , 54.0 , 40 , 1409 , 3045 , 0 , 2 , 0 , 0 , 19.0 , 16 , 0.8370 ,
2016-03-17 09:56:55 , 1227.7 , 1800.0 , 53.0 , 40 , 1414 , 3048 , 1 , 0 , 0 , 0 , 27.9 , 16 , 1.0310 ,
2016-03-17 09:56:56 , 1227.7 , 1800.0 , 53.0 , 40 , 1403 , 3048 , 0 , 0 , 0 , 0 , 29.8 , 16 , 1.0310 ,
2016-03-17 09:56:58 , 1227.7 , 1800.0 , 52.0 , 40 , 1394 , 241 , 1 , 0 , 0 , 0 , 29.8 , 16 , 1.0310 ,
2016-03-17 09:56:59 , 988.4 , 1502.3 , 52.0 , 40 , 1393 , 189 , 0 , 0 , 0 , 0 , 27.8 , 16 , 1.0180 ,
2016-03-17 09:57:00 , 135.0 , 162.0 , 51.0 , 40 , 1409 , 189 , 0 , 3 , 0 , 0 , 9.0 , 16 , 0.8430 ,
2016-03-17 09:57:01 , 135.0 , 162.0 , 51.0 , 40 , 1412 , 182 , 1 , 4 , 0 , 0 , 9.2 , 16 , 0.8430 ,
2016-03-17 09:57:02 , 135.0 , 162.0 , 50.0 , 40 , 1410 , 183 , 3 , 6 , 0 , 0 , 9.2 , 16 , 0.8430 ,
2016-03-17 09:57:03 , 135.0 , 162.0 , 50.0 , 40 , 1405 , 183 , 1 , 4 , 0 , 0 , 9.2 , 16 , 0.8430 ,
2016-03-17 09:57:04 , 135.0 , 162.0 , 50.0 , 40 , 1401 , 183 , 0 , 3 , 0 , 0 , 9.2 , 16 , 0.8430 ,
The CPU LOG:
CPU-Z TXT Report
Binaries
CPU-Z version 1.75.0.x64
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
-- Core 4
-- Thread 0 4
-- Core 5
-- Thread 0 5
-- Core 6
-- Thread 0 6
-- Core 7
-- Thread 0 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.429 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 8 (max 8)
Number of threads 8 (max 8)
Name AMD FX-8320
Codename Vishera
Specification AMD FX(tm)-8320 Eight-Core Processor
Package Socket AM3+ (942)
CPUID F.2.0
Extended CPUID 15.2
Core Stepping OR-C0
Technology 32 nm
TDP Limit 125.0 Watts
Core Speed 1404.9 MHz
Multiplier x Bus Speed 7.0 x 200.7 MHz
Rated Bus speed 2609.2 MHz
Stock frequency 3500 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
L1 Data cache 8 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
L3 cache 8 MBytes, 64-way set associative, 64-byte line size
FID/VID Control yes
Min FID 7.0x
# of P-States 7
P-State FID 0x18 - VID 0x0A - IDD 13 (20.00x - 1.425 V)
P-State FID 0x15 - VID 0x0B - IDD 13 (18.50x - 1.412 V)
P-State FID 0x13 - VID 0x0C - IDD 12 (17.50x - 1.400 V)
P-State FID 0xD - VID 0x14 - IDD 9 (14.50x - 1.300 V)
P-State FID 0x7 - VID 0x1D - IDD 7 (11.50x - 1.188 V)
P-State FID 0x1 - VID 0x27 - IDD 5 (8.50x - 1.063 V)
P-State FID 0x10C - VID 0x30 - IDD 4 (7.00x - 0.950 V)
PStateReg 0x80000185-0x00001418
PStateReg 0x80000185-0x00001615
PStateReg 0x80000173-0x00001813
PStateReg 0x8000015C-0x0000280D
PStateReg 0x80000145-0x00003A07
PStateReg 0x80000131-0x00004E01
PStateReg 0x80000125-0x0000604C
PStateReg 0x00000000-0x00000000
Package Type 0x1
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Base TDP 7 Watts
Boosted P-States 2
Max non-turbo ratio 17.50x
Max turbo ratio 20.00x
TSC 3511.8 MHz
APERF 3924.7 MHz
MPERF 3511.7 MHz
Attached device PCI device at bus 0, device 24, function 0
100 00000000 00000000 00000000 00000000
110 00000000 00000000 00000000 00000000
120 00000000 00000000 00000000 00000000
130 000000C1 00000000 00000000 00000000
140 00000000 00000000 00000000 00000000
150 00073900 00000000 00000000 00000000
160 00000000 00000000 00000400 0066E066
170 00000109 00000000 00000000 00000000
180 00000000 00000000 00000000 00000000
190 00000000 00000000 00000000 00000000
1A0 80000003 00000000 00000000 00000000
1B0 00000000 00000000 00000000 00000000
1C0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 000000FE
1E0 00000000 00000000 00000000 00000000
1F0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 1
120 00000000 00000047 00000000 00000000
130 00000000 00000000 00000000 00000000
150 00000000 00000000 00000000 00000000
160 00000000 00000000 00000000 00000000
170 00000000 00000000 00000000 00000000
1A0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 2
100 00000000 00003B48 00000000 00000000
110 00000100 00000000 044CA424 0CE00F7B
120 0020C00E 00000000 00000000 00000000
130 BC1E3018 3434F2B8 7024F1F0 CC9F3003
140 00000000 00000000 00000001 00000109
160 00000000 01F83EE0 00000000 00000000
170 00000000 00000000 00020000 18640118
180 000000A0 00800004 33000000 00020000
190 0B010000 0F480892 8D0F4007 00000000
1A0 031D0200 00000000 00000000 00000000
1B0 0FC39001 480F7D26 00000000 00000000
Attached device PCI device at bus 0, device 24, function 3
140 00A11755 00000055 0000C12A 00000000
160 C00A0FFF 00000000 C00A0FFF 00000000
170 C00A0FFF 00000000 00000000 00000009
180 017003E3 00000000 08000210 00000008
190 00000000 00000000 00780400 00000000
1A0 00034104 00000000 00000000 00000000
1B0 03EE0627 00000000 00141000 00000000
1C0 00000000 0003CCCC 00000000 00000100
1D0 00000000 00000000 002B170F 00000000
1E0 00000000 80001387 00000000 00000000
1F0 00080000 00000000 00000000 004C074F
Attached device PCI device at bus 0, device 24, function 4
100 00000000 00000321 00000000 00BE01DA
110 000FE001 00000000 0107000B 00000000
120 00000000 00000000 00000500 00000000
140 0F55C96F 000002CA 26B31D37 00000828
150 00000D6C 00EDCABE 00000000 00000089
160 00600F20 00000003 00000000 00000477
180 E000530F 00001003 00000000 00000000
1A0 00000008 00000000 00000000 00000000
1B0 C3B56C81 C3B56C81 001D01F8 00000000
1C0 00000187 00000110 00000000 00000090
1D0 00080000 0000FFFF 00000000 00000000
1E0 0B0A1418 0B0A1615 0AE61813 0AB8280D
1F0 0A8A3A07 0A624E01 0A4A604C 00000000
Attached device PCI device at bus 0, device 24, function 5
120 00001111 80000000 00009130 00000000
160 0000680F 00000000 00000000 00000000
170 00000808 0001A038 00000000 00000000
190 2233457A 0000000B 00202020 00000000
Temperature 1 30°C (85°F) [0x1D] (Package)
Power 0 47.40 W (Package)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02040008h
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Eh
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 8 thread(s)
CPUID
0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00600F20 0x00080800 0x3E98320B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x00000006 0x00000000 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x00000008 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000
0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00600F20 0x10000000 0x01EBBFFF 0x2FD3FBFF
0x80000002 0x20444D41 0x74285846 0x382D296D 0x20303233
0x80000003 0x68676945 0x6F432D74 0x50206572 0x65636F72
0x80000004 0x726F7373 0x20202020 0x20202020 0x00202020
0x80000005 0xFF40FF18 0xFF40FF30 0x10040140 0x40020140
0x80000006 0x64006400 0x64004200 0x08008140 0x0040C140
0x80000007 0x00000000 0x00000000 0x00000000 0x000007D9
0x80000008 0x00003030 0x00000000 0x00004007 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00010000 0x00000000 0x00001CFF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF040F018 0x64006400 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F
0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000
0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001
0x8000001D 0x0001C163 0x0FC0003F 0x000007FF 0x00000001
0x8000001E 0x00000010 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000008
MSR 0xC0010061 0x00000000 0x00000040
MSR 0xC0010062 0x00000000 0x00000001
MSR 0xC0010063 0x00000000 0x00000001
MSR 0xC0010064 0x80000185 0x00001418
MSR 0xC0010065 0x80000185 0x00001615
MSR 0xC0010066 0x80000173 0x00001813
MSR 0xC0010067 0x8000015C 0x0000280D
MSR 0xC0010068 0x80000145 0x00003A07
MSR 0xC0010058 0x00000000 0xE0000021
MSR 0xC0010015 0x00000000 0x09001011
MSR 0xC001001F 0x00404000 0x00810008
MSR 0xC0010071 0x01000006 0x34011615
MSR 0xC0010070 0x00000000 0x34011615
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x01080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000011 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x02080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000012 0x00000101 0x00000000 0x00000000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x03080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000013 0x00000101 0x00000000 0x00000000
MSR 0xC0010071 0x01000006 0x3406604C
MSR 0xC0010070 0x00000000 0x3406604C
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x04080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000014 0x00000102 0x00000000 0x00000000
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 5, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x05080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000015 0x00000102 0x00000000 0x00000000
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 6, Thread ID 0
Type 02040008h
CPUID
0x00000001 0x00600F20 0x06080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000016 0x00000103 0x00000000 0x00000000
