Question Weird keyboard problem - Motospeed CK104
FaithOnHuman
81
Hey there, I have a motospeed ck 104, after some months of use I have a weird problem. When I plug the keyboard to my pc some shortcuts do not work as usual e.g. alt+tab to change windows, shift+alt to change the language. it's like they are relocated. For example, if I use the left alt + tab I can't change windows but if I press the right alt and tab I can, but I have to press enter to jump to the window I want. Also, I noticed that shift +number buttons do not show the right characters. For example, if I want to type a hashtag # I have to change the language to be able to type #.
Some more info:
  1. I am on the latest windows 10 build (fresh install)
  2. I don't face the same problem with any other keyboard
  3. I tried to unplug and replug the keyboard & reset it with (fn+esc)
  4. I use two languages EN + GR
Any ideas? :unsure:
