Weird lag / sound issues
snasty11
14
Hello, I have had this problem in the past but i fixed it some how but now that i reformatted I am having the same issue and cant figure it out. When im playing games i get weird sounds like its breaking up it gets loud coming from my speakers or headset and i start to lag really bad it has nothing to do with my speakers or headset it does it with both of them. It happens more on more graphic intensive games. like say dying like does it pretty much constantly i cant even really play it but then games like league of legends sometimes it does it some times it doesnt but when it starts i have to restart my computer to get it to stop then ill be able to play like one game and i have the same issue again. I have all latest drivers and also tried updating bios. Any input helps thanks!
System -
OS: Win 7
Motherboard: Sabertooth z87
CPU: Intel 4770k
Memory: 8GB Gskill
Hard Drive: Kingston 128 SSD 500GB WD
Video Card: x2 Galaxy 670 GC sli
Headphones: Sennhieser HD 598
Monitor: BenQ XL Series XL2420TE 144hz
Play the game with one GPU running(non-SLI) and see if that helps. FPS will be slower. If the game is better, no weird sound glitches or frame skips, then your problem is with SLI or the other GPU. SLI is more likely, and that is driver related....
here are my scores P14415 with 3dmark 11 and with
unigine valley
fps 93.6
Score:
3914
Min FPS:
37.9
Max FPS:
179.1
System
Platform:
Windows 7 (build 7601, Service Pack 1) 64bit
CPU model:
Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (3500MHz) x4
GPU model:
NVIDIA GeForce GTX 670 9.18.13.4752 (2048MB) x2
Settings
Render:
Direct3D11
Mode:
1920x1080 4xAA fullscreen
Preset
Custom
Quality
Ultra
not sure if those are good for my setup
