I have recently bought a prebuilt computer off of the internet, and it has been running flawlessly. I have been playing crysis 2, bad company 2 without a problem. Recently, if the CPU has too much load it gets to a point where it just switches off and the fans spins to max speed. My system is as follows;
-AMD Phenom II x6 1055T @ stock w/ stock cooler
-ASRock 870 Extreme3
-8Gb DDR3 PC3-10700
-ATi 6870 1Gb
-Hitachi 1Tb sata 2 HDD
My normal CPU usage on idle is about 1-4% and sits at around 38-41 degrees C (with 3.5k RPM on the fan speed), when I load a demanding game, such as Bad Company 2 the CPU goes up to 60% and the temp hits the mid 50s (with 4.5k RPM fan speed) then after ~15mins it cuts out, black screen and the fans rev up. This has only started to occur recently, I have not made any changes to the system (in terms of hardware) and nothing I know of on the software side(but that is hard to pinpoint). I am thinking that it may be caused by;
-The stock cooler/the thermal paste may be failing or wrongly applied?
-The ASRock OC utility has this CPU temperature limiter that maybe affecting it?
This has only happened recently, as I was able to play these without a problem.
Cheers for the help.
-8Gb DDR3 PC3-10700
-ATi 6870 1Gb
