Hi,
This is my first build.
This morning, I got everything working just fine - installed Windows, drivers, games, etc. I checked the system several times and it was working normally.
However, after shutting it down for about 7 hours, I turned it on and it is not working properly.
Symptoms:
Case: SilverStone Raven Series RVZ03 Black Mini ITX Case
Motherboard: MSI MPG Z390I GAMING EDGE AC Motherboard
CPU: Intel Core i5 9600KF
GPU: Gigabyte Radeon RX 590 GAMING, 8GB
PSU: Corsair CX650M 650W Bronze Power Supply
CPU Cooler: Cooler Master GeminII M5 LED CPU Cooler, Low-Profile
Case fan: Cooler Master SickleFlow X 12cm non-LED Black Fan
SSD: Samsung 860 QVO 1TB 2.5" SATA SSD - MZ-76Q1T0BW
RAM: G.Skill Aegis 8GB (1x8GB) 2666MHz DDR4 Desktop RAM
OS: Windows 10
What should I do now? As this is a mini case, I don't really want to pull everything apart after building it though.
Symptoms:
- All case fans run for like 1/10 seconds and then turn off
- PSU fan also run for like 1/10 seconds and then turn off
- This is repeated about every 2-3 seconds.
- The LED indicator on the motherboard says CPU is not detected or fail - it blinks just like the fan so I am not sure whether it is indicating the CPU is failing or not. I checked Youtube and it should be a continuous light.
- This repetition of turning on/off can be shut down if I hold the power switch for like 10 seconds.
OS: Windows 10
