Question Weird PC Boot problem
Mar 21, 2020
8
I have Avermedia C985 capture card, I know it's so old but at least it's cheap and useful. Motherboard is B450 Tomahawk, it has 5 pci and 2 of them for GPU. When I take first one for GPU and plug capture, PCs led and fans starts but does not get BIOS screen or anything, just black screen. I switched GPUs PCI (I mean second one) then plug capture card, it worked great but my GPU performance reduced. Do you guys have solition or advice?
https://prnt.sc/rkiueu
Mar 21, 2020
8
You should try putting it into the first slot again without your capture card if you havent already if it still doesnt work its possible that pci slot just doesnt work anymore
Im already using it on first slot as i said all pci slot actually work fine but only when I switch GPUs PCI slot.
