Monitor Brand: Starlogic
Power Board: EMAX
Symptoms:
Monitor sometimes works and then after a while it will cycle on and off. One second on, shuts off, then one second on, shuts off .... continues as long as it's plugged in or I time the pressing of the power button to turn it off. Sometimes, disassembling it (unplugging the lcd from the power supply) it will work - coincidence?
Now, I mean it turns off. It doesn't go into sleep mode. The power indicator led goes from green directly to off - do not pass orange standby.
When the monitor is briefly on, all I see is the multicolored "DVI" on the top left hand side of the screen. When I shine a flashlight on the screen, I don't see the desktop.
What I have done:
Replaced just about all the caps, except a 4.7uF that is glued in and a very large one (400V+) that looked in great shape. After removing a cap that was nestled in the middle of other parts, I saw that it was a bit buggered on the side that wasn't visible. I thought that was it!
When I first fired it up, it proceeded to act like it did above and then when I hit the power switch, it was working fine. I was able to turn it on and off and I thought I fixed it.
Until, I remembered that I forgot to put the screw hex mounts on - the ones that you use to screw in the VGA cable. Plugged it back in and back to the power cycling.
Thanks for any ideas! If anything, it has gotten me reviewing my electronic s.
Power Board: EMAX
Symptoms:
What I have done:
