Hi guys, could use some help here as my head is about to explode! I just recently bought this case "http://www.amazon.co.uk/gp/product/B00606NA0A?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00" after setting everything up i noticed the machine would not power on, i tested things like RAM, GPU, CPU and even changed the PSU however nothing helped. I then looked at the front panel connectors, i decided to use my old case's, switch and front panel connectors as a bypass and lord be hold the machine booted into life. However! And here is the strange part...
I next decided to check whether or not it was the wire that was the problem or the switch itself. I used a volt meter to check the current on the wire, it was fine. Next i checked the power switch.... it was also fine. I have no clue what to do now! Please help guys!!!
Also Amazon is out of stock with replacements and they have no clue when they are getting them back in stock, so if possible I'd rather not wait 1000 years if i can fix this myself. Cheers!
