[SOLVED] Weird Problem with my tp link archer t6e ac1300. Please Help!
Jul 30, 2019
5
My wifi adapter has this weird problem where when I turn on my computer, either my PC or Windows won't detect my adapter at all. It's not that it won't connect to the internet, it's just that it's like if its not even installed onto my PC. I have reinstalled it three times, installed the driver multiple times, and the Windows diagnostic claims to have solved the problem, but doesn't. The adapter always has its green light on, meaning its there, but its not detected at all. What's weird is that when I restart my PC, everything works just as it's supposed to.
Is there anything I can do, or is it time to get a new wireless adapter?
Motherboard: ASUS ROG B450-F
Adapter: TP link archer t6e ac1300.
Jul 30, 2019
5
which slot did you put the wifi card on?
try another slot?
full system spec?
I forgot to mention that one attenna broke off, and there were scratches on the connecting part of the card. I got a new one, installed it and all and everything works well. Thanks for the advice, though!
Jul 30, 2019
5
try another slot?
full system spec?
