Hello. i'll list my specs at the bottom of the post.
Basically i've been running into these weird sutters while playing games like overwatch, my fps is pretty fine but theres a very annoying stutters and i noticed cpu usage is all the way up to 80% and idk if thats good or not.
Also in other games fps went pretty bad from avg of 110 to 40-60. So i decided to format my c drive and hope that it would get better. While yes the fps did get better but the stuters are getting worse and i really dont know what to do.
I tried the following:
my specs are as follows:
MB: Gigabyte b365m aorus elite
CPU: INTEL i5-9400F
RAM: TridentZ 16GB (2x8@3200MHz(MB only supports 2666 tho))
GPU: asus dual rtx2070s 8g evo
Storage: Lexar NM100 256GB
PSU: CoolerMaster 750w 80+ White
idk if im missing anything but that should be it hopefully
- making power plan high performance.
- changing nvidia control panel global settings to best performance possible.
- playing on lowest settings but still same fps.
- turning on XMP on BIOS settings.
CPU: INTEL i5-9400F
