Hello,
I have this weird issue where my computer either freezes up completely or freezes up and restarts shortly after logging into Windows. When it does restart I get the nvldmkm.sys error that seems to be quite common with Windows 7.
However, after about 2 or 3 times of freezing, it will stop completely and my system will be stable. This only happens when my PC has been off for a while and I turn it back on. It's not a backbreaking issue but it is annoying and may be symptomatic of a more serious problem that could bite me in the butt later, so I want to get this figured out.
When I get the freeze and restart, the system is able to create a dump file for me. Here is the contents of that dump file:
Use !analyze -v to get detailed debugging information.
BugCheck 116, {fffffa80088664e0, fffff880104f5d00, ffffffffc000009a, 4}
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+6eed00 )
Followup: MachineOwner
And this only happens on the desktop! After 5-10 minutes, when my system is stable, I can run games and do whatever just fine.
I ran checkdsk on my system drive and ran 2 passes of memory check, all was fine.
Below are my specs:
MSI H55M-P31 motherboard
4GB G-skill DDR3-1333 PC10600
EVGA Nvidia GTX 470
i7 875k @ 2.93 ghz
PC Power Supply and cooling 610 watt PSU
WD 150GB 10000RPM drive
Hitachi 1TB 7200RPM drive
Thanks in advance for any help you can give me on this matter!
Below are my specs:
EVGA Nvidia GTX 470
i7 875k @ 2.93 ghz
