Weird problem with WG 25K7193
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I've got a WG 25K7193 that runs fine until I *barely* flex the
board. If I give it just the slightest push in the area around the
heat sink on the right, above the RGB+Sync inputs, the high-voltage
cut off circuit kicks in. I can't find any bad components, bad solder
joints or broken traces. What could cause this?
Please see my arcade and pinball items for sale:
http://www.videoracer.com/forsale/
Or check my repair logs:
http://blog.videoracer.com/blog/
G
Guest
Guest
R89 has broken away from the copper pad. You won't see it until you
actually unsolder it.
Sometimes I've actually had the HV shutdown pot go bad.
