Not sure which category this falls into (mods you can change it if you wish) but its homebuilt so I guess this should be it...
Home built my rig about one and a half years ago. I7 920 (OC'd to 3.4ghz), Two GTX 460 768mb's (Neither overclocked) 4GB corsair ram 1600mhz, Asus P6T SE (flashed to normal P6T for SLI. Flashed it right when I had built it and has always been fine), Windows 7 HP 64bit and a Corsair 650TX PSU.
Was playing football manager 2011 while listening to last.fm, as I always do... then suddenly, the computer froze, the audio was repeating itself, then blue screen, restarted automatically. Happened over about 2-3 seconds. My first question is how do I make it so it doesn't auto restart? (so I can put down the error code). This was about 20 minutes ago.
After the restart it was fine, I just assumed it was one of those rare random blue screens that you get very rarely, so I went straight back to what I was doing. But then again, the desktop froze and the sound was repeating for about 2-3 seconds, but this time, no blue screen, the computer continued fine as usual, this was about 10 minutes ago, so I decided to make this thread...
Any thoughts on what I should do/what is going on? My temps are fine, using a Zalman CPNS 9900 cooler, never seen my CPU go above 70c, even on everest stressing, and i've never seen my 460's go above 60c even at only 40% fan speed. Possibly ram? I dunno. Been running fine throughout writing this thread.
