Question Weird sound from Graphics Card
leapingliger
5
I have a EVGA 1080Ti Black Edition, and for a while now it’s been making this weird noise. I thought it was hitting a cable or something inside the computer, but even if the fans are not running on the gpu, and the gpu is not anywhere near any components it makes this noise. I would appreciate any input.
https://youtu.be/8w4zSrSnMos
erik62905
126
16
715
9
Well if you're sure it's not the fans or coil whine from load then I suppose it could be a capacitor. Has it always had this issue or is it relatively new? If it's a new issue then I would RMA to EVGA.
leapingliger
5
It has always had this issue. I'm sure that the fans aren't hitting anything. I can definitely still RMA to EVGA if this is an issue, but the issue has been there since I've had it.
erik62905
126
16
715
9
Yeah I’d RMA if you’ve always had the isssue. It could get worse and whatever’s causing it has a chance of breaking the card.
