weird sound from hdd
nightingale little
36
i am getting some weird sound from my harddisk attached is the video...previously it wud get detected at times and at other times it wud give cant find system disk error i did scan and bad sector recover using hard disk sentinal which showed the health at 80% but it wud still give the same detecting error . someone suggested i check the head and i did saw it was stuck and so set it but now it gives buzzing error+ wont detect..is there anyway i can repair it..[video="https://www.youtube.com/watch?v=W9FkpB1grDQ&feature=youtu.be"]https://www.youtube.com/watch?v=W9FkpB1grDQ&feature=youtu.be[/video]
Only if that data is absolutely irreplaceable and vital.
Either way, that will cost $$.
This is why people (like me) harp on backups.
A dead drive should never be more than..."aw crap, I have to get a new drive"
You data should never be affected.
It was dying...almost dead.
By opening it up, you simply turned off the life support and dug the grave.
It's dead.
There might be one last chance -- check with Dr_Luke first about this:
A DR company/specialist might be able to "move" your platters from the source HD into a target twin HD. I'm only guessing, check with Dr_Luke before sending HD to a place.
